Camaro Research Group Discussion => Decoding/Numbers => Topic started by: chevysscamaro68 on April 18, 2007, 11:27:57 PM
Hey guys, should the last 6 digits on the VIN on a camaro match the cowl tags six digits after NOR?
No, the VIN and tag BDY Fisher body sequence numbers are two different things.There is some degree of corellation however.
Read this link:
http://www.camaros.org/numbers.shtml#CowlTag
Thanks guys, my only other question after reviewing the above link given, is on my cowl tag I have UU as Paint code , chart only shows U , what is the other U???
First U is the lower lower body paint code, second is the upper body paint code. In your case both the upper and lower body is the same color. If you had a Vinyl top then the second letter would be replaced with a number like 6 for white vinyl, or 2 for black.
