Camaro Research Group Discussion => Decoding/Numbers => Topic started by: itsazooitellya on April 26, 2022, 10:06:13 PM
Can anyone help me with these pad stampings? I included the block and head numbers although the heads are newer. It is "supposed" to be a Chevy 302 out of a 68 z-28. Is it? If not what the heck is it??
124378N455370 was the car the 1968 302 was in. Engine was built in Flint June 10th 1968....Joe
Thank you, so the stamping looks legit?
Pad is good IMHO
Three months from casting to build?
Heads aren't correct. I don't see anywhere that shows the block casting date? My comment was strictly about the pad stamp.
This it?
Yep and doesn't change my previous opinion on the stamp.
Okay, thanks again
So is that block cast date E228?
That is what I am seeing.
I see the same, which falls right in line with the Assembly date.
UPDATE: After further inspection, the engine is sized, has mismatched pistons, and a crank with the number 3941174, 327? So now my question is what is just the block worth? It is currently still 4” bore. The windage is intact also. Trying to decide whether I walk away or not. Does seem like the block should be with something though. 🤷♂️
It’s only going to be worth the most to the person with the car. Oddly enough I have another Z 1,000 vins off this one in my data. Just the block can go anywhere from $1k-3k depending condition.
Block is fine, 19 days from casting to assembly is not unusual.
Std bore with no ridge which will clean up without oversized pistons would be the best case scenario.
N355370?
IS the car around?
If it is seized because of rust, that may not hurt the value too much, will probably still need bored regardless. If it is seized because the block is cracked from freezing or something else, it could very expensive to fix, if it can be? Years ago, a buddy bought a 427 block at an auction. It looked good. After together and in the car, he started getting water in oil. It had a crack looking from underside, up in cam galley area. Maybe worth fixing today, but he junked it.
I know of a 67 L71 engine which had MUCHO damage from a thrown rod, bottom of cylinder, pan rail(s) The owner took it to high end engine builder and told him if it took 3 years and 25k he was ok with it... well 24 months and 12k later the block was solid and square without windows.
Canadian documented 67 L71 with N89 and N14, I figure 12k to keep the original block was money well spent.
Ok, thanks all!
