Camaro Research Group Discussion => Originality => Topic started by: DAVID CHAMBERS on June 03, 2021, 05:27:48 PM
what is the correct size for my 69 Camaro engine wiring for the braided cloth split wiring sleeve. And where is the best place to buy it?
Where do you want to use it. I think the only place I've seen it is on the temp sender wire...Joe
Yes sir there and I would like to hide the new wires for the pertronix add on.
NAPA used to have it. I don't know now. Asphalt coated cloth....Joe
I have Never known the Asphalt Cloth to be "Split", it is woven and does not hold shape when spilt axially. They do make a modern corrugated plastic tubing that is split.
Ebay, American Auto Wire and Local Swap meets are good sources for this item, I have had trouble sourcing locally & often get a blank stare at my Counter man when searching for the Gooey Cloth.
I this used in basically two places on the F Body: Temp Sender and the Start leads.
A friendly suggestion for hiding the pertronix lead would be to procure some Harness (NON ADHESIVE) Tapes and re-wrap or over wrap as needed.
Thanks for your help.
If you only need the asphalt cloth, HERE'S (http://www.truckandcarshop.com/67-81Camaro/Camaro2019forweb/Camaro_2019.pdf) The Truck and Car Shop's offering (see below). Check out page 204, P/N 67-16701 for a whopping 4 bucks. Classic Industries probably carries it as well as most other vendors.
Long Island Corvettes sells it:
https://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000370a~Z5Z5Z5AACYF~P4.00~~~~S62D15UH0H69126493280i~Z5Z5Z5~Z5Z5Z50000370a
Amazon....
https://www.amazon.com/Original-Restoration-Accessories-Motorcycle-Tuning_Store/dp/B07ZY667C3/ref=sr_1_5?crid=1DYPT7HJZ7W1J&dchild=1&keywords=asphalt+cloth+wire+loom&qid=1624712674&sprefix=asphalt+cloth+wire+loom%2Caps%2C258&sr=8-5
