Camaro Research Group Discussion => General Discussion => Topic started by: WaltZ on April 29, 2021, 02:08:25 PM
any thoughts on what this pump is. the leaker out of my camaro
40987 (P/N 6470779) was used on literally millions of GM cars and trucks with a 350 or 307 from the early to late 1970's.
would that include a Z28 302
No. As a matter of fact, no high HP cars at all. Just basic 305 and 350 engines.
40669 was the assm line original part number for a 1969 302....joe
grabbed a delphi MF0001 AMF0001.
that's all that was available locally, it works
is there something better that will have a similar appearance and possibly better performances.
Depends on how much you want to spend! Your Delphi will work just fine, or you can get an NOS AC DELCO (https://www.ebay.com/itm/274778250297?hash=item3ffa0f5c39:g:GKkAAOSwK21gSXgT) similar appearing pump on ebay for around $100 or so, or you can go really expensive and get a rebuilt 1969 Z28 DATE CODED (https://www.ebay.com/itm/293505128783?hash=item445644d94f:g:CFoAAOSw3Ztcv9Y2) pump for several hundred!
An original 69 Z pump
Dont even bother buying from the guy on ebay in the link ( Paul Baker at Goat Hill Classics). He will just take your check and cash it and never respond to you.
Ditto on that guy!
I don't recommend "rebuilt" fuel pumps anyway (even if you're having your car judged) so I would just go with a NOS pump that "appears" to be correct. Like that DELCO PUMP (https://www.ebay.com/itm/274778250297?hash=item3ffa0f5c39:g:GKkAAOSwK21gSXgT) on ebay I previously linked to.
I don't think anyone is reproducing the 69 Z28 pump but you might want to check with the major vendors.
I ordered a "rebuilt" pump for my Z from a large vendor. It got here and the logo was wrong and the weep holes. No signs of corrosion. I sent it back and they called me irate that I would say it was a reproduction. He said I have 6 more of these in stock what date do you need. He called back all of them had the same date.... So at some time, someone was restamping reproduction pumps with z part number. This was like 4 years ago
