Camaro Research Group Discussion => Maintenance => Topic started by: MD396 on April 05, 2007, 01:08:58 AM
What is the factory valve lash for the intake and exhaust valves on my 1969 Z28 with the original motor and solid lifter cam?
Thanks in advance,
David
David, look at the 302 valve adjustment article under CRG reports. The information at the top header of this site is very helpful.
Fireman John
Here it is:
http://www.camaros.org/302valves.shtml
Got it. Thank you for that link.
David
I use a timing tape that does the same thing I actually had one balancer marked off to match the tape make the process much faster two revolutions and your done.
