Orphans - documentation or VIN-stamped drivetrains - in search of the original cars => 1969 - Orphans => Topic started by: ZLP955 on July 23, 2020, 09:13:06 AM
Muncie M20 for sale on ebay.
Assembly Stamp P9C26A
Partial VIN 19N630559
Possible full VINs:
124379N630559
124679N630559
Ebay auction: https://www.ebay.com/itm/1969-Camaro-M20-Muncie-Wide-Ratio-4-speed-transmission-SS-Z28-W-VIN/383641442065
Seller ID: harleyjim
Item Location: Webster, New York USA
Starting Bid $899.99
Description:
You are bidding on an original Muncie M20 Wide ratio 4 speed trans from a 1969 Camaro. VIN is stamped on the side.This was recently taken out of a 65 Chevy truck and was in working order. The inside is in good shape and has no chipped or broken gears and the syncros are not heavily worn. 1 mounting ear has been repaired and is fully usable. 2 of the tail shaft bolt holes are stripped, so they will need to be heli-coiled.
VIN 124379N630559 shows good on vinaudit.com
- Warren
There are times that guys pull out the Muncie then install a 5 speed or 6 speed, and they never look back.
Relisted with Buy Now $999.99
https://www.ebay.com/itm/1969-Camaro-M20-Muncie-Wide-Ratio-4-speed-transmission-SS-Z28-W-VIN/303637134930
