Camaro Research Group Discussion => General Discussion => Topic started by: WaltZ on May 13, 2020, 03:14:14 PM
I have the original 120 mph speed minder unit and with a continuity tester everything has checked out. Only the speedometer is an oer.
all wiring is correct.
I added a ground to the speedo base (maybe this is the issue) but does not work without it grounded.
Tried a resistor in line, but acts the same.
When it contacts to buzz, the tach goes crazy.
Also, the copper contact on the speedometer needle heats up to a glow.
worked in on my desk with a 9 volt battery and works and does not seem to over heat the copper contact wire.
Also replaced the voltage regulator with the correct oer made in USA.
I am replacing the 70 amp alternator with a properly coded 37 amp as soon as it is delivered, could this be it.
Driving me crazy!
thanks in advance
Any ideas out there?
With the ground wire attached do you still get the crazy tach and hot contact? I believe there should be a separate ground wire from the instrument cluster. A star washer under the ground wire will make a better connection.
yes, crazy tach and hot contact. it's attached with excellent continuity with star washers.
With the engine on, what's the voltage? That will tell you if the alternator or volt reg is an issue.
betwenn 12 and 13 volts
Are you sure that the wire from the tach - going to the coil is on the right terminal? I'm pretty sure it should go to the negative terminal.
I'm thinking that's your problem....ground loop...
That's good. Changing the alternator and/or regulator won't change anything....
YES the tach wire goes to the negative side of the coil on a 69 Camaro.
here is a schematic Kurt posted a few years ago on Camaros.net which he attributes ED B as the creator.
(https://www.camaros.net/forums/attachment.php?attachmentid=105449&d=1427293958)
Sounds like the buzzer may be grounding through the tach. Is it an in dash tach or separate tach mounted on the column or someplace else? Where is the buzzer supposed to ground?
I'll give schematic a try and will let you know.
In dash oer tach
factory wiring
thanks for the info
Yea that is what I was trying to determine... where the grounding was occurring, because there is a direct ground which is causing the contact (point of highest resistance) to heat up.
Maybe the resistance is too high for the buzzer to get enough current or the buzzer requires more current -
Who swapped the original speedminder stuff onto your replacement speedo?
OR do you have a repro speedo and speed minder mechanism as ONE unit?
And everything else is original?
IF you have repro speedo speedminder needle contacts etc...
DID you fully service your original parts? FULLY clean ANY contacting points for harness connections?
Did you ensure the plugs are actually contacting with zero ohms resistance?
The tangs on the bottom of the highram?
The packard terminals, did you remove the metal terminal ends from the harness plugs and use a fine wire brush and clean them and lube them with connection compound?
The resistance (current load) BEFORE getting to the highram may be too much for the circuit... There is NO DOUBT in my mind that a reproduction contact is going to be inferior by orders of magnitude to the original delco component.
For cleaning original harnesses...
I pin a harness down to a 6 foot long 2 foot wide piece of plywood with a sheet of paper which I draw out all the connections - label all the harness ends and wire colors, then unwrap the harness, clean the connections, and repair any damage, prior to rewrapping in harness wrap and installing the plastic ends which I run through the dishwasher a few times (in the utensil baskets).
I made a tool to remove the terminals from the plastic plugs using a piece of stainless tig wire which I hammered flat and then filed to the correct width. I made a loop on mine to wrap around my thumb so I can use both hands to manipulate the plugs under a dash etc when fixing wiring problems on "restored" cars... Sorting out wiring and glass fitment issues on "professional restorations" could be a FULL time job if I wanted it...
(https://lh3.googleusercontent.com/QK4m1quU6SQljmLZ0WzBaJi2ovl9NhCwK6C1XbkAshAHigfYlua2hPzBk9W5kpoUaumsTcU5Xnd8GNzrVGdU7zVYvk4hll3WPhZVNm218uOcxs4TkJjojrbFGtK5Dm0CV8ONgHMwu55T6utuUd56z-xwdn8wjjBRsNsUTEMMGobC3KVPMsu2VG5vpSEGhLtKOorpoYwsvmNfVuoAyxmzHRCDgjN7YhVarXGVXMojxd2aua54wluqKVQLdWxFYHMS-QsXoZxCL-0jI2ImEMf9_-wJqHPO-_VtNqE0Eycfs3eseOxnpLRrs8Gs4NLFId7PAPSPKO4Hm-ttxaQEef5PEHkLMCBXKqWTvkN_5TNbxhXleEvk-z32rKpJNodrxr6TyBvU7IRH9Q7-sZJZG8083tu-txFCMXfz8QxkHyH0NbZN1LkiOaja-ozWoHR6B6ud0rTOK6mrZgr06ef6UH6NpcDLJbTV-KM4EhifwUeycW2qpqc4jOdUjEPb0XgWDfwfhI3U2tBp1TbLdJCwC39zmvcQcKGnD6_uXJoI-pBtHFUBNbVp6r7aVxtIKjzdWJraEOp2LJZeNmZgKx0a_5f1Xz4_gsYv1gbVcVhj2FpCVh_O35cYTwV9iJJ-6hcuyxK1wJaDpYnViTnra5cmA7SS4f28aK_hn1EyQVyN3E2BczCGtDH_Ih7D4hFipwaHYQ=w731-h1095-no?authuser=0)
(https://lh3.googleusercontent.com/pTH3-zuO2CH7gOac3nzeq8HYl6JE7Q1cDB-blKBMqYamb4ni5XUUmSqZBPUMGl7nLpH0oi969dLVBCEvBY7EIA6uwtMe_w4xbhhmg4odXRmE2NIR7WbF_NuW0TLpo6pn_6GnNcAF-DKrEvu350lb4KBN-yKVm_dGzAiudrmpAlGAnYWL5fIEc7AktlvcGp7_MZeGlxnpTYvQOfmyY4-FAwHR-mOKX7gNrseQ1eo24s5xhMNUOyG5Cp3EwXTRPHpE4JrZIdg3fFv61GbpL3E3r8OluJpZBL06H_cpewAA6v8BACdHXart0_rZKTF6XF0eWgv3X88iBLGB-pd2R9e3OqGMPwKUL1vPDi1U49Lt53TXaW_1R5NRY9ZqeiFrx10umSfbdxGxQwS_IAKgxYo78xm2Pe8-cTSqSqYwYqcQzMy5y3QLM16evbduZ8kGvvlox4t6SoBwYygTVvqjAMlWYrgS_5-Ad7Srg0ok2EaSDLo0JEa73x1aLAaPOyGRfEkmJVbBLJRsPa88E1WEmY8JAvq9Gv2Xpg7aGuCXJj5pOv07dwPUgdjecikunWUbela2w2BIS7jLG-hfHOsNLfvcrWJzjXnw2HG_nrXOQVXnDlCebytkBRDpwAaJ0ZutjpaNFTb3nc2vQ7GYkdvlT-DGeMCdl-lWoNNHFWqfFm9UP8L4yK8CA_hcwxBB7Ppn5A=w1550-h1034-no?authuser=)
all terminals and wiring checked.
buzzer cleaned and contacts filed and ohm tested.
the only piece changed from original kit is the speedometer which I stated is an oer.
will recheck and try again this weekend.
thanks
The speedometer and SPEEDMINDER come together from OER correct?
OR did you put an original 1969 speedminder on a OER speedometer?
IF the speedminder is OER then I suspect that is your problem.
Either get another OER speedminder and try it or find a GM original speedminder speedometer.
Only the speedometer is oer,,,,,, the rest is factory and tested.
The speedometer and SPEEDMINDER come together from OER correct?... No such kit available, parts sold seperately
OR did you put an original 1969 speedminder on a OER speedometer?.... YES I did
No such kit available? What is this OER speedometer ?
OER Part # 6482888 Speedometer with speed warning https://www.oerparts.com/product/6482888.html (https://www.oerparts.com/product/6482888.html)
that's the one
I suspect THAT is your problem... I recommend you find an original assembly line speedminder speedometer.
James, maybe I've misunderstood your question, but the OER speed warning speedometer is a reproduction of the original AC factory item, you still need the separate buzzer cable and harness as per the AIM.
Do you actually believe that the contacts and the materials are of the same quality, NTM of the same exact design tolerances as the original? personally - I do not believe that I have found any type of reproduction small electrical item near as well built as the original part - contacts typically are no where close to as robust as original delco components, and many times the contact area of the surfaces is out of alignment and so small there is nothing to do but heat up.
I suggested trying another OER repro speedminder speedometer assembly earlier just to ensure that the contacts are not the problem as I believe he said they are heating up, thus I theorize not enough current is reaching the "buzzer"
you can cause the contacts to burn together without enough current... that is what happens with the autowinding clocks in 60's GM cars... as the battery dies, and there is no longer enough current to wind the clock when the contacts come together they heat up and burn together -according to the instrument repair guys around the corner at D&M this happens at around 250mA.
FWIW a 9 volt battery brand new is about 500mA unless it's lithium which is around 1200mA.
So there probably isn't enough current to cause the copper strip to glow.
Give D&M (Greenville SC) a call they rebuild all GM gauges including speedminder speedometers.
No, clearly I did misunderstand your question. I would never suggest any electrical item by OER exceeded the original in quality. I read "The speedometer and SPEEDMINDER come together from OER correct?" to suggest the separate factory parts (speedometer and minder/buzzer) were combined within the OER unit, and now realise you meant sold as a package.
Thanks everyone.
Also thanks for the D&M call contact, will give them a try too.
