Camaro Research Group Discussion => Restoration => Topic started by: bobs69z on November 21, 2019, 12:41:09 AM
Does anyone have a pic. or part number for top radiator shroud bolt for a 1969 with 302 engine? thanks Bob
9419380. All small-blocks are the same.
Also used [2 pc] to secure the plastic fuel pedal support to the cowl and the clamp at the base of the steering column.
If someone could provide a pic, and if there are any markings on the head. My white 69 is in need of at least 1
Why not check the same screws in the other locations I noted?
That is what I am saying, I have 2 different kinds of bolts in those locations, and my shroud had a sheet metal screw. Maybe I can remove the 2 styles and post pics, and see if either are correct.
FWIW here's what AMK shows on page 78 of their catalog. I suppose as with most fasteners, there could be more than one supplier/head marking
https://www.amkproducts.com/wp-content/uploads/Catalog_BulkFastener/BULK_71-88.pdf
Thanks for the replies. I found the right ones at Heart Beat City. Using part#9419380.
William are you referring to the plastic moulded rectangular piece just below the steering column?
No; the metal trim plate clamped at the base of the column.
Thanks William for the idea to look for other places in the car that used the same fastener.
I looked at the Z10 I am restoring last night. A lot of stuff on it has been messed with over 50 years, but I am pretty sure these places had not been touched. The plastic gas pedal bushing and the steering column all had the same 4 screws that Pete showed, but with an E on the the head.
Now to convince the Legend Judges you don't need the small bolt with the big washer on the radiator shroud...
Ok I went through the AIM. Page 132 ( UPC 9 A4) shows the area under the dash where the clamp is, for those that may have trouble locating the 9419380 bolt/screw.
OK now when I look at page 147 in the AIM ( 11/13 B4), I see the clip (3939394) and the washer (120386) . Is there another location that the washer is used?
I put one on there for now but I know it is not right. thanks
(BTW my original screw/bolt has a "D" on it.)
Washer #120386 is not found anywhere else on a '69.
William your a wealth of knowledge, thanks for the help.
