Orphans - documentation or VIN-stamped drivetrains - in search of the original cars => 1969 - Orphans => Topic started by: luv2sixty9 on November 08, 2019, 11:10:06 PM
Trying to reunite this original short block with the car. The block still retains the original standard piston and there is no ridge, so it can possibly remain standard bore.
The VIN is present but hard to read 19N7005?
Will need more of the VIN if possible. Did you try gently cleaning the area with lacquer thinner?
Is this block still available @luv2sixty9?
