Camaro Research Group Discussion => Originality => Topic started by: KevinK on March 14, 2007, 06:16:59 PM
Are the smog tubes the same for a car that came with A/C as they would be for a car withOUT A/C? ...IF they are different, ...what is the difference? (IF different, ...I assume it would be due to the compressor...)
...car in question is a CA '67 327/275hp with A/C (w/smog)
Kevin
...anybody?
Kevin,
My answer, I think so. I know what they look like with A/C (My L48 has AIR and A/C), not positive on the without. I can send you a picture of the tubes and manifolds from my car if you would like.
Dan,
If you could post a photo(s), ...that would be great. I do still have the original tubes off my car, ...however they've been 'modified/fixed' so they're tough to go by (the driver's side isn't bad though).
The ideal situation would be to see pics of tubes for A/C and non-A/C to do a comparison...
Since I'm not in a big rush, ...I'll be checking around Carlisle this summer ;)
Kevin
...I'm still not sure about the smog tubes, ... A/C vs. non-A/C, ...however at least I'm glad to see the tubes from my car (L30 w/AC) and Dan's car (L48 w/AC) do appear to match up. I'll continue to follow up on this, but thought I'd post these pics so far.
Here is a photo of the smog tubes from my '67:
Note: Top is the PASS side tube, ...bottom is the DRIVER side (and yes they have had 'attempted' repairs of years ago, ...that brazing looks like bubble gum...)
(http://photos.imageevent.com/hvclassics/camaro/67327275hpblackplate/websize/IMG_1089.JPG)
Here are two separate photos from Dan:
PASS side:
(http://photos.imageevent.com/hvclassics/camaro/67327275hpblackplate/websize/P_ex.jpg)
DRIVER side:
(http://photos.imageevent.com/hvclassics/camaro/67327275hpblackplate/websize/D_ex.jpg)
Here are the manifolds from my '67. It's doesn't have AC. I prefer to keep this vintage smog equipment in a box in the garage. ;)
(http://geocities.com/sdampier@sbcglobal.net/Team_Camaro/Smog-003.jpg)
(http://geocities.com/sdampier@sbcglobal.net/Team_Camaro/Smog-004.jpg)
(http://geocities.com/sdampier@sbcglobal.net/Team_Camaro/Smog-005.jpg)
(http://geocities.com/sdampier@sbcglobal.net/Team_Camaro/Smog-006.jpg)
