Camaro Research Group Discussion => General Discussion => Topic started by: jim28607 on August 03, 2019, 10:53:49 AM
Are 1967 and 1968 door shells the same ?
Thanks for your help
I know the hinges are way different, 3 bolt as opposed to 4 bolt. The outer door skin has a different part number, probably because the wing window? I would say no...Joe
Thank You
No they are different, not only hinges....the inner shell is different also 67 has finish painted metal top and set up for vent window. 68 has upholstered top.
True. I forgot about that. The bottom is also like the top. Much smaller door panel...Joe
