Camaro Research Group Discussion => Restoration => Topic started by: Kevs67 on March 10, 2007, 07:00:58 AM
I have a new dash pad for my 1967 Camaro. Are there any pictured instructions on how to remove the old and install the new one? I know that there are 4 bolts attached to the pad, but I need to know how to get to them thru the dash....
Thank you in advance,
Kevin Fentress
kfentress@sport.rr.com
Do you have the '67 Assembly Manual?
no I do not but, I do have the 1967 CHASSIS Service Manual and the Camaro Restoration Guide 1967-1969.
The Assembly Manual is a "must-have"; all the Camaro parts vendors have them for about $20.00.
I just ordered the Assembly Manual. Thank you.......
There are several references that are constanly noted here...
Start here: http://www.camaros.org/geninfo.shtml#InfoSources
Also, Ed had a post a while back that gives several other good references. You might want to hunt for that... or he might see this and post it again...
Thanks JohnZ, I got the 67 Assembly Instruction Manual today. Also, thanks to lakeholme for the great references link.
