Camaro Research Group Discussion => Restoration => Topic started by: Southerner on March 09, 2007, 05:28:00 AM
Hi, this is my first post on this forum. I am restoring a 69 Camaro. The heads are 3927186 castings witha date code of J 11 8 and J 28 8. They are the big valve 2.02 and 1.6. Untouched and unported.What I want to know is, did the Z28 motors heads come with guideplates or without in stock form ? As these heads have no guideplates and the (I presume) press in studs.
The cylinder block that these heads came of is casting 3932386 4 bolt block date code I 25 8 The build date of the 69 body is 12B.
So is it possible the early 69 camaro Z's came out with the non guideplate heads and the later model 69 Z's as the production progressed come out with the guideplate heads.
No 69 Z's came with guideplates. There were also no screw in studs.
So what I have got here is some stock standard Z heads that came off that block then. Thats another question the block was cast on I 25 8 ..... 25th Sept 1968 and the build date on the car is 12B.... 2nd week Dec 1968
I had mone machined for Screw-in studs (7/16) and guid plates... the 7/16 studs keep the valve train more stable.
i would probably like to keep mine original. the body of the car is going to be the fun.....Oh boy. It has been in CA most of its life, But I have and will be replacing most outside panels.
FYI,
Original 2.02 heads have an unshrouded polished area around the intake valve in the combustion chamber. If that is not there, this could mean they were opened up at a local machine shop. Most shops who open 1.94s to 202s do not have the proper eq to finish the job right.
Jerry
FYI,
Jerry
Jerry,
Do you do this service and/or have this equipment?
Thanks Jerry, I will go have a look and send a pic. Mike
My machine shop does. They use a certi machine to do these conversions. And you are better off starting with a 194 head. The valves are always sunk too far in original 202 heads when you find them, building a new 202 head from a 194 valve head gives you a fresh factory type valve job. DO NOT INSTALL HARDERED SEATS!!!!!
Jerry
Jerry
Why Jerry? ???
Because there's VERY little metal left between the valve seats on 2.02" heads as it is, and it's very easy for a shop not intimately familiar with these castings to go through into the water jacket when cutting the recess for the seat, at which point the heads are scrap. The seats are NOT necessary unless you're towing a trailer at 100mph all day long or the engine's going in a boat.
Thanks for posting that John. I couldn't have said it any better.
I am suppose to be getting a pair of heads later this month where a seat fell out and did a lot of damage to the valve and combustion chamber. Another reason why not to install them.
Jerry
Jerry
I think I'll have you do mine. I already have a Dz motor that's now worth about $10.00!
$10... just about anything can be fixed... even if she needs to be sleeved or cracks welded up... if the engine is original to the car you do whatcha gotta do.
Not original to the car, unrepairable crack at main #2. :'(
Fixing cracked cylinder heads is dicey at best. Most of the time when it's important, the "cold lacing" process is about the only thing that can be done......and that doesn't work all the time.
We are trying to save a 1969 Z28 original block now. One of my clients bought a car and when we got the engine apart, it was cracked in the lifter galley. Botched repair and the whole nine yards. It's a mess but we will do our best.
Jerry
Sounds like it froze... that happened to my boat when I didn't winterize it one year... made the 454 a nice anchor... live and learn... I was being lazy and it cost me... BIG TIME...
Thanks John. I've never heard that before! My car has been stored for 26 years and I have not "fired her up" because everybody tells me to install hardened valve seats before I do. So lets see... I need to change all the fluids and install a new battery... ;D
Is using a certi machine all that's required when openong up a set of 1.94's to 2.02's? Is there any additional unshrouding required?
delete
The heads built as 2.02's at the factory had an extra unshrouding cut on the chamber wall adjacent to the intake valve; if you convert 1.94's to 2.02's and don't make the unshrouding cut, they'll flow less air than they did with the 1.94's. Photo of a factory 186 2.02" chamber below.
I understand that but does the certi machine cut that extra material or is additional unshrouding necessary after using a certi machine?
I believe it is all about how it is set up- the answer being yes, maybe or no! The Certi machine makes cuts, not grinds so it is just another part ( step) of the operation, but might not be done if not specified ( sorry about the crappy explanation- its late!).The bottom line is it needs to be done if you go to 2.02, so see that your machinist knows that- the Chevy Power book says you need to go for a 2.34" total profile width. Also, David Vizard has an excellent book on working the -186 casting for performance.
Good luck-
Would this Vizard book work for the 291 68 Z heads? Were the chambers the same for 68 and 69 Z heads?
It is a very good book, applicable to all of these late '60's- early '70's 64 cc heads which we are speaking of, with flow figures, Mods., a really good book plus has some great stuff on the aftermarket heads as well.
ISBN is 0-87938-547-2
How to build and modify small block Chevy Cylinder heads David Vizard , 1991 MBI Publishing Co
