Camaro Research Group Discussion => Restoration => Topic started by: ko-lek-tor on April 19, 2019, 01:24:52 AM
On the rear side marker lights, is there a gasket on the outer side under the chrome bezel? And, a foam gasket on the inside? Anyone have a picture of the assembly apart showing the order of assembly, like an exploded diagram?
Bentley. Here's a picture of a car that has 12k original miles. I would say it's correct....Joe
There is no gasket under the chrome bezel. The gasket is on the sidelight side and gets pressed against the inside of quarter panel.
- Warren
Part number should be 3945721. Only one gasket listed. As Warren indicated, between the light & the inner rear fender. None used on the front...Joe
Here's a picture of the compressed gasket after the light was removed on my LOS car, showing the gasket wasn't installed parallel to the stamped hole in the quarter - just like in Joe's picture.
Much thanks amigos. I had forgot exactly, or unsure enough, that when asked by another fella restoring his car, I could not give a concise answer, nor find a picture. Thanks, again.
