Camaro Research Group Discussion => Maintenance => Topic started by: dab67 on March 04, 2007, 11:51:52 PM
Can someone tell me what is considered good cylinder pressure for a 40 year old 350 v8? 200 p.s.i. 185 p.s.i.??? I looked through my Chassis service manual for 1967 and it shows how to test but doesn't say what the cylinders should be, unless I am looking in the wrong place, what is considered good pressure? If I remember correctly all eight cylinders should be within 10 percent of each other. Is that correct? For that matter, what was the pressure for a new 350 back in 67?
dab67
150 would be good then and now.
Thanks Steve
BTW, I think the max variation between cylinders was/is 20 lbs.
dab67 -
You can find that information in your chassis service manual in the specifications section. Compression specifications are found in the tune up chart specs. The compression spec in my 1968 chassis service manual for a 350 is 160 psi at cranking speed, throttle wide open with a maximum variation of 20 lbs. between cylinders.
Steve and Paul:
Thanks for the info!
Dave
Dave,
It might be a better idea to do a leak down test instead of a compression test. This is more of an exact science and will give you the percentage of leakage in each cylinder. In a race car, these engines leak about 2-3 percent. In a street car, it's more like 6-10 percent which is about normal. Just some food for thought.
Jerry
Jerry:
No clue what a leak down test is. Enlighten me!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dave
You pump air into the cylinders from an air compressor source. Most leak down tester kits have a hose with a threaded fitting that screws into the spark plug hole. Once installed, it measures the amount of leakage from the cylinder on a gauge.
This is by far the best way to tell if your rings are good or bad.........and if the cylinder has good seal. Here is a link to one on Ebay right now. Good luck!
http://cgi.ebay.com/ebaymotors/NEW-CYLINDER-LEAK-DOWN-TESTER-TEST-DIAGNOSTIC-AUTO-TOOL_W0QQcmdZViewItemQQcategoryZ43989QQihZ014QQitemZ330093865626QQrdZ1QQsspagenameZWDVW
Jerry
The beauty of the leakdown tester is that in addition to the actual leakage rate, it allows you to identify the source of the leakage; if you hear noise through the carb, it's an intake valve; if you hear noise through the exhaust, it's an exhaust valve; if you hear noise through the oil fill hole, it's rings, etc. Much better diagnostic tool than a simple compression tester.
Dave -
If you decide to check the state of your engine with a cylinder leakage test each cylinder to be tested must have the piston at TDC (top dead center) on the compression stroke, so that both valves are closed. If the piston is not in this position you will get a reading of 100% leakage! Have fun. :)
thanks for the info John and Paul, I will find out if my partner in crime has a leak down tester or if he knows someone that does.
Dave
Dave
I have two if you what, you can take one to play with.
Mike:
Thanks for the offer, greatly appreciated. My friend has access to one. Once we get everything put back together on my car we may do both tests just for the heck of it.
Dave
I built my own leak down tester and it works well. For those of you wanting to tinker a bit check out this web site.
http://www.xs11.com/tips/misc/misc3.shtml
Wallace
I have a question. Can this test be done on an engine before it is installed into the car. the reason I ask is I just bought a 454 for the 68 and i would like to do this test before installing to see if I have to pull it farther apart.
What do you guys think??
Leakdown readings will show less leakage if performed when the engine is still warm from running. On the other hand, leakdown testing should be regarded as a tool to locate problems that are present from one cylinder to another. Results can vary depending on the level of pressure applied to the cylinder, the efficiency of the tester, and the expertise of the testor. Don't focus on trying to attain an elusive 1% reading but rather look for gross leakage such as 15% or more in one cylinder or significant variations from one cylinder to another. For general purposes, variations of 5% might be a sign of a problem on one cylinder. If problems seem to be present there are several strategies that can be used to narrow the range of possible sources. First, I'd run a check and determine if significant variation is present.
