Camaro Research Group Discussion => Restoration => Topic started by: Buzz67 on October 10, 2018, 02:21:45 AM
Hello Members,
Where can I find "foundry" black spray paint? I'm told that's what is supposed to be used on master cylinders.
It was a cheap flat to semi gloss which the castings were dunked in prior to machining.
(https://lh3.googleusercontent.com/4ZbCLQ97AMMSj6XqI_Y6m1tpagK4Z3cMllWekLvwxy5c9_KmchDnaBoJVx0ob2AN7_WVt2EHfIqvAq6lkp7lR6CtK_VVDM128RH_nMaAVlTJKqn3Mgj_TKwJyqK16Udnj9gjR3RNfv_9lR0fcq9lVo8c9Ga1mCJmAvnveiomKl15bUfaRqhPtq6iPgn-0OCS_0-ifRMemE_0WNuW3LzZQcrDeobq40u72KW-qmmg1dTo1khq5YNbLSrizOCSqD86OSlcufkEhE7qNpvyKIkxK0il9gjpmu37cunZSm8NkNeORoMKCpbYr_6eyyfh5C9c4t-d1lJ9mEHL7sxJRaFW8xSUeLc5-Qb4L02kOs3csf4azbd1j3JYLI2mtu6k7KFCGYCSsha9mx4Sn4ubVy2fU50tVDaqpiqjaSuKOmmF0ec9IjUhkRd_FJUFiORKZb-7Yj6wAuTSeCrGv3kL4ugJeyv1k3bzbNpvi-IijBZsxFGlDNLCUxfuytk7NaRgHV61Pelh0NGeDFy1jcKXH9jg4pBdAoDZpwEmj1ouexDw25sPqdiKsjtawkaJMncxaHvOFeSbYeBNP4ozvcNgfYEzHc-9l79fzPSoTYu0R2mt8exOLVuHlAJZFruEVPFVqdEpqUKKg2oElbQ_V17CqqYLFt5TMOb76aakcBOblVyrWMFsDR24F2PmcjDC=w1024-h764-no)
Yep. You can rattle can it and it should look ok.
Nice job on the M/C. Makes me want to refinish mine now.
