Camaro Research Group Discussion => Originality => Topic started by: SS396 on April 06, 2018, 05:55:50 AM
Could someone please post a photo of or link to the correct shift lever that bolts to the selector shaft on the side of the trans. The ones for sale that are supposed to be correct, differ from seller to seller, so I'm not sure which one is right.
Floor or column shift in case they're different?....Joe
Sorry, I forgot to mention that it's floorshift.
With or without center console? They are also different.
Bob
Centre console.
LOS TH400 w/ console (68)
Cool. Thanks 169INDY. As I said the repo ones look nothing like this and I can't find an NOS one anywhere. Anybody out there have a nice secondhand one for sale?
Seems like a simple piece to make ?
Jim (169INDY). Could you please verify this for me as it's a bit hard to tell from your photo. Which cable bracket does yours have, and does your lever have a slot or hole for the cable pin?
Regards Larry.
(Slotted) for the input lever.
The retainer looks like this.
Thanks Jim, you've come up with the goods again. At least I know with your car it's original, so there can be no doubt.
Regards Larry.
Regards Larry.
Original parts that have been fluffed;
Disclaimer: they should be natural (Bare steel) I Zinc Dichromate plated them in the 80's & GM replacement shifter cable
JIM
