Camaro Research Group Discussion => Restoration => Topic started by: z28rays on February 09, 2007, 02:42:11 AM
I am in the process of restoring a 1967z28/RS, and I if the car should get rs emblems on the fenders, and if so, exactly where do they go? I also am in need of many parts for the car. If you have any please feel free to contact me. Thanks, Ray
RS emblems do go on the fenders and it's very tricky to install them in the true position. In all the years I've been judging, 1967 RS emblem installation looks like a train wreck on most restored cars that I've seen. I have original tracings but I will not send them out. Maybe I can make a copy somehow. It's very time consuming to do this right.
Jerry
Hi Ray -
You need to get a 1967 Camaro Assembly Instruction Manual (AIM). This is the book the factory used to assemble the cars on the line. It's listed on the following link with some other good books you will need for your restoration:
http://www.camaros.org/crgrefs.shtml
Hope this helps and good luck with your restoration!
Others have tried to work with the assembly manual. Hard to do. The best way for the best results is to make a tracing from an original RS fender and overlay the tracing paper on the new fender.
Jerry
Hi Jerry -
Do you know how the holes where located and drilled at the factory? Where all the holes drilled in exactly the same place on every fender? How about the original tracings you've made, are they all exactly the same? I'm curious. ???
Paul,
There were punched from the factory and true position was right on the money with every origianl car that I've seen. There is no easy way I can explain this templet to you. It has to be taped on the fender a certain way. Maybe John Z can shed some light on how the factory punched the holes in the fenders. I have used this tracing several times and it's right on the money. Did my 67 turquoise Z28, and many more.
Jerry
Jerry -
You should figure out a "sure-fire" way to position your tracings on the fender and then market them. $$$ ;D
I would but there's more money in appraisals and certifying cars. Maybe when I retire I will do that. Right now there are just not enough hours in a day to get it all done.
Jerry
Jerry -
Since we're on the subject, how much is it to have my Z/28 "MacNeish certified?" ;)
Where do you live?
Paul,
There were punched from the factory and true position was right on the money with every origianl car that I've seen. Maybe John Z can shed some light on how the factory punched the holes in the fenders. Jerry
Each fender was loaded into a hydraulic piercing fixture which clamped and located it precisely; the operator then turned a valve to the position with the combination of holes required for that particular car's style and option conditions and pushed a button, which actuated the desired combination of hydraulic piercing dies to create all the emblem holes required. None of the holes were drilled - all were pierced.
JohnZ -
Thanks for the info! The piercing method would account for the little pieces of metal still hanging on the back side of the hole I often see.
Where do you live?
Jerry -
I'm in Redwood City, CA. "Climate Best by Government Test" 8)
http://www.ci.redwood-city.ca.us/
Well, that's a two day trip and expensive. Maybe I can work you in with another client's appraisal. I will be flying into Ontariio, CA. Is that close to you?
Jerry
Jerry, Redwood City is up in Northern California however, Ontario is only 50 miles from my house. When you going to come into town and where you headed?
Jerry
Jerry -
I was afraid you were going to use that dirty, little word: "expensive" :'( Well, I'll just have to wait until I get her running again and then I meet you at Barrett-Jackson or some where like that. How much is just the "certifying" portion with no travel expenses included?
Ed -
You're right Redwood City is located in the San Francisco Bay Area, 25 miles south of San Francisco and 27 miles north of San Jose. If you're ever in the area, stop by and check out my baby.
Ed,
I'll give you details when I schedule the trip. It will be about three weeks from now. I don't have any other info right now as the guy called and asked me to put him in my appointment book. It's a guy who bought two 69 Z28's at BJ.
Jerry
Paul,
If you bring the car to my shop, it's $250 for the inspection certification and three page written report.
Jerry
Jerry -
That's more in my price range! Thus, I'll bring the car to you sometime (?) in the future. It sounds like you need a West Coast associate/apprentice! :) So, where do I send my resume? ;)
Ed -
Fifty miles from Ontario should put you in Murrieta! ;)
Paul,
Good guess??? Or did you already know that!!
Just a lucky guess Ed!! ;)
