Camaro Research Group Discussion => Restoration => Topic started by: Mike S on November 13, 2017, 09:51:28 PM
Was the factory applied battery felt washer that went under the + terminal a certain color?
I don't recall seeing those used on cars fresh from the assembly plant, with top post batteries, back in the day. But we'll see what our experts say.
It's listed in the '67 UPC 12/A4 for an L6 engine. The V8 engine refers to the L6 for the + cable. The felt washer P/N is 378082. I see some Corvette places sell it for '67 but it is almost colorless. I was checking to see if there was a color used for Camaro.
Mike, the 378082 felt washer was used on the positive side of all cars and trucks with top post batteries from the 1920's! However, since they were soaked in 90wt gear oil before installation, it really doesn't matter what color the "naked" felt was because the 90wt turned it a very dark brown.
Hi Ed,
Gear oil....that's interesting to know. I guess the Corvettes used the same felt and their repro is a bland color...almost a very light brown (dry). I was wondering if the felt was something like what is available today from the auto part stores which are red and green felts.
Thanks!
Has anyone ever seen one on a survivor Camaro ? I have never seen one.
Yes, I have Charley. My very first Camaro was a 1967 SS/RS I got from the original owner back in 1971. It still had the original battery!! I remember because I had to replace it like the first week I owned the car! I don't remember the actual color, but it was very dark. Close to black, but that may have just been because of age. I haven't seen once since.
I picked up a few felt washers when I stopped by LI Corvette.
Here is a picture. I may dampen it with some 85W gear oil.
Does anyone know why these felt washers were only used on the positive terminal?
I'd experiment with red or green store bought pieces and see if that color can be closely duplicated. Either by soaking in a solution or dye. Cheap enough to experiment with anyway.
Or you can fabricate your own with a couple larger round punches. I suspect the original were a bit more dense and thicker that what they sell at your FLAPS today. McMaster has this felt, some off-white:
https://www.mcmaster.com/#felt/=1agdpf2
As I recall, the + terminal is the one that always corrodes and caused problems, and why they only put the felt there. If there's a chemist in the house, they can tell us about ions etc. and why the case.
Corrosion is produced by the normal process of sulfation and electrolysis, where minute amounts of electrolyte migrate between the seal of the battery posts and the plastic, causing any metal it's in contact with to turn into sulfates. Since this mostly occurs on the positive side of the battery (because of electrical properties), the felt isn't required on the negative side.
If you're really interested, do a Google search on sulfation and you'll get a TON of hits!
