Camaro Research Group Discussion => General Discussion => Topic started by: hrlyfxdl on October 31, 2017, 04:55:09 PM
Hey guys, I searched through different posts and couldn't find an answer. On my 68, the rubber plunger inside the washer pump has a big hole in it so it won't spray. Gotta fix this to pass safety on my car...ugh. Anyway, I've looked and found two options, but not an expert on which part would fit my 68, since that pump is different than other years and I'd like to keep it original instead of replacing with a new washer pump. Is there someone who rebuilds these that anyone knows of, or do it myself? If I do it, does anyone know of a place to buy a replacement part? The only one I could find was on ebay: part # 4918445 (I don't have a parts catalog to tell me if this will work, and the AIM only lists the entire unit). Or should I buy a used one, there is one on ebay, and scavenge the parts off of it I need? Thoughts and input greatly appreciated. Thank you
This may work?
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000370a~Z5Z5Z5AAAYZ~P19.00~~~~S51R0RUAFD69126519650g~Z5Z5Z5~Z5Z5Z50000370a#
This is on the LI Corvettes web site
I'll order that part today and see if that will work. Thank you for the link. Any other info would be helpful as well.
