Camaro Research Group Discussion => Restoration => Topic started by: Tinkerr on January 30, 2007, 09:22:54 AM
I'm ready to install the brake booster and pedal assembly. my question, does the firewall/insulation pad get sandwiched between the brake pedal assembly and the firewall or does the pedal assembly mount directly against the firewall? thanks
The forward flange on the pedal support mounts solid against the inside of the firewall; there's an inverted "U" cutout in the dash mat that provides clearance.
We can always count on you to have the answers. Thanks John
