Camaro Research Group Discussion => Mild Modifications => Topic started by: dab67 on January 17, 2007, 04:43:24 PM
I am thinking about upgrading my SBC Distributor to Electronic. Any recommendations on what brand to buy? I want it to look as original as possible with a black cap etc.
dab67
I'm using a Pertronix module inside my original distributor. It's been in their for 5 year with no problems.
Kris
I am also using the Pertronix (Ignitor II) in my original distributor, along with the Flame-Thrower Black coil. The paint on the coil is a bit shinier than the stock coil. The label can also be peeled off. Looks pretty close. I put it in about a year ago on the recommendation from someone else using the Pertronix in a similar set-up and it has been running great.
Kris and AD:
Thanks for the input I will check out the systems you two are using.
dab67
If you want to go completely stock looking (in other words, one wire going to the distributor instead of the Pertronix two), check out the BREAKERLESS STELTH (http://www.lectriclimited.com/breakerless_se.htm) system. I've not used it myself, but others have. No complaints so far (other than the price).
Same here,I just put a breakerless stealth in my original distributor with the original coil.I recommend it to anyone.works great.
