Camaro Research Group Discussion => General Discussion => Topic started by: NAPA68 on August 23, 2016, 02:08:45 AM
124379n607712. I owned the car until around 2003 and sold it to a fellow around Miami FL.
Tim
Orange RS/Z.
Don't know where it is now. Did it have a window sticker with it?
Were you in Wisconsin when you owned the car?
Yes I was (am) and will post a copy of the window sticker
Tim
I need to get the file shrunk down so Photobucket can take it.
Tim
How about this?
(http://i66.tinypic.com/wi5aj5.jpg)
The car also had what I thought...................were some cool over the counter parts
OTC JL8 rear end
J56 calipers
Daytona? springs. Sat about an inch lower than any other Z28 I had seen
Old Koni shocks.
Did not know much about these cars back then. Certainly did not know what I had.
Tim
Tim,
I sent you a PM with some information that might help you track her down.
Do you have any old pictures from back when you owned it? How original was it? Original 302?
Good luck and I hope you find her!
I do have some pics around here somewhere.
Original motor, trans, heads. I had to rebuild the motor (piston pin) and the damn machine shop decked the block when I specifically told him not to. Thankfully, its a Norwood car and the stamp on the casting was legible.
Tim
Thanks!
Wow nicely equipped... not too often does one run across a REAL Documented Hugger Orange RS/Z with gauges, Chambered, ZL2, VE3, & 4.10's.
I'm supposed to go look at this car over the weekend. The owner is looking to sell it.
Orange RS/Z.
Kurt,
Yes, it has a Window Sticker
