Camaro Research Group Discussion => General Discussion => Topic started by: paulmanta on July 31, 2016, 03:40:45 PM
Hi all, I have a standard early 67 Camaro fitted with a speedo and fuel gauge and since I have had it the fuel gauge seems to read whatever it likes.
Did the gauges read min and max between the lines or are they supposed to use pretty much the whole of the dial face ? If I fill it right up the needle will point to around 5 o-clock and if its empty it will read below the min line, maybe to around 10 o-clock.
It doesn't look like any of this has ever been fiddled with, dash is original and the sender is undisturbed.
The gauge reads high and low but its massively exaggerated, is this normal or do I have a problem ?
