Camaro Research Group Discussion => General Discussion => Topic started by: camaroman1969 on December 29, 2015, 01:34:12 AM
Hi guys. Have a question. Drive shaft U-Joint has two (2) brackets holding it on drive shaft. Brackets have numbers 1 thru 4 stamped on top of the bracket. Does anyone know why?? thanks!
Got a photo?
I suspect you mean '.. two brackets holding the rear most U joint to the differential..'? :)
U-joints are pressed into the driveshaft...
I agree with John, a photo may help.
