Orphans - documentation or VIN-stamped drivetrains - in search of the original cars => 1968 - Orphans => Topic started by: 1968RSZ28 on October 14, 2015, 03:35:06 PM
A 327cid/210hp (LF7) engine is on eBay...
Engine pad is stamped: 18N346975 V1113ME
Block casting number: 3914678
Block casting date: K 9 7
Seller id: 1029ron
Seller location: Ansonia, CT
Seller contact info: 203-714-6262
http://www.ebay.com/itm/201448229154?item=201448229154&viewitem=&vxp=mtr
No sale 10-20-15...
Reserve not met = $875.00
1968 CHEVROLET CAMARO 327/275 HP ENGINE
ENGINE PAD; VI113ME
DATE CODE K97
MANIFOLD 3919803 DATE J247
ENGINE RUNS FINE IT WAS REMOVED FROM A 1968 CAMARO TO REPLACE WITH A BIG BLOCK
MISSING CARB AND FUEL PUMP
I ALSO HAVE THE ORIGINAL POWER GLIDE TRANSMISSION THAT I CAN SELL SEPARATELY
I thought the suffix code "ME" was a 327 210 hp two barrel engine. I have never seen one with a partial VIN before. Was 68 different?
The engine is a 327cid/210hp (LF7) engine as stated in my original post. Kurt just copied and pasted the seller's description from the listing to show the engine was probably removed from it's original chassis. Yes, in '68 all Camaro engines got stamped with the partial VIN...
http://www.camaros.org/numbers.shtml#PartialVIN
Seller's description from eBay listing...
ENGINE PAD; VI113ME
DATE CODE K97
The seller is incorrect about the engine application, it's a 327cid/210hp (LF7) engine. The 4-barrel intake manifold was installed after the car left the factory.
