Camaro Research Group Discussion => Restoration => Topic started by: Mr 396 on September 04, 2015, 11:53:46 PM
Needing to put the grille back in my '68. Does the hood latch support brace need to come out? Any suggestions on best way to put in?
Need any help you can suggest as I would like to install today.
Just from looking at the L78; I dont see that it needs to come out but I havent had to remove the grille from a 68 before. I know on my 67 I didnt have to remove it. Although it would make it easier to access everything. I would probably remove it simply due to it not being that big of a deal to remove and install.
Thanks. I will need to work with the lower part of the header panel to get it in as the previous owner was not a gentle person when it came to removing things.
I know one thing - it's tight. You have to compress the grille to get it to clear the header panel and pop in place - scares the devil out of me to do it. I've had mine out for repair for a while - not really looking forward to putting it back (about ready to replace it with an NOS grille I have anyway).
You can do it without moving anything, just be careful and take your time.
