Camaro Research Group Discussion => Restoration => Topic started by: 67rs327 on August 02, 2015, 02:50:51 AM
I have the entire drive train out of my '67 L30/M20 and thought I'd get a few comments on what I should look to repair/replace while I have lots of room to work. Car is getting a new clutch (all associated parts like flywheel, bell housing, linkage, Saginaw, Hurst, etc. rehabbed) I also installed new manifold flange studs. What else? Oil pan gasket? - Do I need go thru jacking the engine up to remove the pan? Rear main is not leaking at all. Thoughts? Thanks.
If it ain't broke, don't fix it. You might just give yourself a problem where there was none before. Spend your time and money where it counts. These cars are EASY to fix as needed down the road.
Just about every 'driver' 1st Gen I have seen needs upper control arm bushings. Usually cracked and crumbling. You would have to compress the springs to get the arms out but no better time than now.
Along the same line as William suggests, I will add, is replacing the sub frame bushings. I also agree with the advice of, "If it ain't broke...don't fix it.", as well.
Thanks Gents. I have the subframe bushings on the list but think Ill leave it at that. Exhaust flange studs were in rough shape so needed replacing - no hope of spinning the old ones out even with heat as there was < 50% of material left where the stud met the flange......that turned into a drill and tap excercise x6.
3/16 pilot followed by 5/16 followed by 3/8-16 tap incase anyone is looking for something to do for 4 HOURS.
