Camaro Research Group Discussion => General Discussion => Topic started by: 69 Zee on June 29, 2015, 04:14:27 AM
I don't mean to beat a dead horse on trim rings and caps but I wasn't sure whether to start a new topic or add to my previous thread http://www.camaros.org/forum/index.php?topic=12511.msg104775#msg104775 since it pertains to my 69 Z 03B build
Please move if necessarily better.
I pulled my center caps out after reading several threads in reference to them. I never gave them much thought as to being correct or not as they all looked identical at first look. I'm missing the original rings but believe I have the original caps. So I figure I'd post pics and get your thoughts. Three of the four caps have a "double rib" on the inside and one has only "one rib". But all have the same part number or what appears to be the part number.
I'm also in the market for original trim rings and from what I now know they should be with the four black clips and complete oval valve stem hole.
Thanks all in advance :)
