Camaro Research Group Discussion => Originality => Topic started by: Edgemontvillage on April 16, 2015, 04:46:29 PM
I recently purchased a 1969 RS/Z project car that at some point had headers installed. The reverse lockout rod was disconnected and the bellcrank unbolted from the frame likely to deal with a common pipe interference issue. All the original exhaust hangers remain and almost unbelievably the reverse lockout bellcrank was left dangling...for how long I don't know. I want to reconnect the bellcrank to the frame and need to know which bolts are correct. Please post a photo if you have original bolts.
(http://i1187.photobucket.com/albums/z396/edgemontvillage/Camaro%20Parts%20References/Bell%20Crank%20Reverse%20Lockout_zpsnutvdjc0.jpg)
Lloyd...The 1969 AIM, Section M20, Sheet A7 shows the setup for a Muncie equipped car and states that the number is 9419402. Here is a link to the AMK site showing the bolt (Page 117, 5th bolt down).
http://www.amkproducts.com/Catalog_PDF/109-127.pdf (http://www.amkproducts.com/Catalog_PDF/109-127.pdf)
Lloyd,
I have seen two different bolts that are the same styles, but the one has a "D" in the center and is the most common of the two from what I have seen. Dave
Is this what the original bolts look like? (I suspect the finish would be manganese phosphate rather than silver zinc or silver cad)
(http://i1187.photobucket.com/albums/z396/edgemontvillage/Camaro%20Parts%20References/Bellcrank%20Bolt_zps9fspbl08.jpg)
Here ya' go Lloyd, 3 real deal originals. They are black phosphate, tapered like a self tapping type, no letter or marking on mine (maybe a faint L). Bentley.
Gold Star Bentley, thank you.
Lloyd, would love to hear more about your latest project!
Yep, 5/16-18X3/4 1/2AF .66 O.D. AMK B-12589 (6) and for sure a phosphate screw. The supplier was a GM supplier and the screw is technically correct size and finish wise IMO Lloyd.
What Bentley posted are correct and is one of the two bolts that I referenced. However, those were mostly used on automatics, hence why he has three bolts. Also the AMK bolts are wrong for the center portion are hexagon and not a circle like the originals.
I will do a post on the new project soon Tim.
