Camaro Research Group Discussion => Originality => Topic started by: wisemanz28 on March 03, 2015, 10:06:38 PM
When did they start using bolts ( instead of using nuts ) to attach shifter rod levers on a 1969 Muncie transmission ? The transmission is a 660 main case and has a 306 side cover.
All 1969 Muncie trans used bolts, the flattened 3/8 type stud was 1968 and earlier
I have a 69 trans with earlier shifter rod mounting studs installed.
Might have been modified over the years. What is the casting number on the side cover?
Early 69 Muncie, Aug.19th 1968.
One more.
3950306 is the number. I think it was modified to fit earlier Camaro.
