Camaro Research Group Discussion => General Discussion => Topic started by: dannystarr on January 07, 2015, 05:54:52 AM
Will 15" X 7" Rally wheels clear everything on my '68 Camaro at stock height? Want to have an extra set, then put on originals for shows etc.
The tires are P265/50SR15 Dunlop GT Qualifier Radials. What say you?... Danny
Danny,
I deceided to keep you company! I would guess that the responses are few becuse there are a few factors to consider, Easy answer is yes. however not all 265.50.15's are the same size, stuffed wheels look awsome stopped but not always good for daily driving. If the springs/bushings are weak/sagging there will be lots of side shift causing rubbing to the inside of the fender wells. a full tank or passangers will lower your car a couple of inches. I have 295 50 15's euro T/A's tucked in my 68 with un-cut wheel mouldings (Multi-leaf springs with Anson ground grabbers,- bolt is in) The rims are 15 x 8 with a 4.5" back space. The only rub I have had was a bad dip on the 405 freeway at high speed. They must have rubbed the tops of the fender wells as there was no markings on the tires. Hope this helps.
Victor
My answer would be:
"The wheels themselves will fit fine, but you'd better check the tires if you go with large sizes like this..." :)
Lot on this topic in Team Camaro--be advised more meat will fit under a 69 then 67/68.
Ok,
I figured it wasn't a slam dunk. And thank you men for getting me started. I will decide what to do. Don't even know if they are still for sale... D
I used to rum FW rally wheels on my 68 years ago before I restored it. I had no problems with the wheels. You might find a p series tire that would have the same rolling diameter as the E70-15 with the correct width....Joe
One factor for sure as many have advised is the tire size especially in the front as tire will rub when turning hard left or right. Old school but I still like the nostalgia look of slim wheels in the front and then the larger 15X7 or even a 15X8 with a larger tire if it fits in the back.
Have fun and know you are!
Jano,
225/60/15 all around. No rubs! ( JonZ68)---take a look :D I like.
Currently I have 255-70R15's in the rear ( fills well nice with no interference) 195-70R15's in the front. on the original DF's. Slight rake ,liked the look. Never was a fan of those huge meats sticking out the wheel wells. Don't like tubbed cars. (mini tubbed are cool!)
My slick is a MT 28x9x15 on 8" rally. no rubs. (posted wrong size on another thread)
The 215/65-15 is about as close as you're going to get to the original E70-15 size appearance-wise; the E70 was 26.4" in diameter, and the 215/65 is 26.0". My all-original '69Z (stock springs) had 235/60-15 T/A's on it when I bought it, and both fronts rubbed at 12 o'clock. I swapped them out for a set of 215/65 T/A's, and no more rubbing.
Here is the ad.. I think I better just try to find another set of 15" X 6". I was just excited cause this set-up has rims, tires, trim rings, and center caps reatogo.. D
http://sfbay.craigslist.org/sby/pts/4830061882.html
Metric to Standard Result:
195/70/15 = 25.7x7.7/15 me fronts
265/50/15 = 25.4x10.4/15 your tires of interest
255/70/15 = 29.1x10/15 me rears
235/60/15 = 26.1x9.3/15 rubbed per John Z
215/65/15 = 26x8.5/15 John Z running now
225/60/15 = 25.6x8.9/15 JonsZ68 (white 68 SS clone/tribute...nice car, reports no rubs)
a few numbers to ponder
http://enthusiast.yearone.com/faqs/wheels-tires-brakes/tire-conversion-chart/
just happened upon this
205/70/15 = 26.3x8.1/15
One advantage of 15x7 wheels, besides their width compared to your 15x6's, is their availability. The 15x7 Rallye wheels (FW code) were used on Monte carlos etc through the '70's and are much easier to find, and MUCH cheaper to buy... :)
True Gary and there were a lot of 15X6 service replacement wheels made (70's & 80's) also that of course do not have a DF stamp and can be purchased fairly inexpensive.
Well I have been checking online every morning and every night for months and have not found what I need. Maybe I will look for the 15" X 7" and just put thinner tires on them. I eventually want to purchase Repro Good Year Wide Tread GT's. But at almost $350 a pop... OUCH!! Anybody know of a good deal? I was talking to Chick on the phone a few days ago and he mentioned he got a great deal. Maybe he has found that company where he purchased his.... However that may have been years ago, I can't remember... Danny
not sure what you are looking for now ? The tires on Craigslist were a bit bigger than E-70's. 6" rims only ? Are the tires on the car now original to it ? If not , why not just order the tires you want and have the mounted on your wheels ?? I put my originals back on 26 years ago, with new tires, and that's what the cars rolling on now. High quality wheels, true, and no slow leaks at the bead. Irreplaceable ? yea,but so is everything else hanging off of and including the chassis.
Danny,
I have an almost new set of the "Firestone Wide Oval 60's", (which are equivalnet to: 235/60/15) I would consider selling at a fair price.
Not sure where you are though......(I am in Northern VA) but just throwing it out there. They look awesome on these cars, IMO.....perhaps better than any OEM tire.
I ran 225x60's on the front & 255x60's on the rear with FW 15x7 rally wheels with no rubbing on my 68. I am going back with the same thing again once the car is finished, in fact I have already ordered the tires. ;D
What size are they? Every tire has its size molded into the sidewall, by law.
OK, SO, I now have 4 - 15" X 7" rally wheels FW code in hand. They were painted metallic silver, so I am hot tanking all 4 of them as I type this. So my speedo is accurate, and the tires don't look funny/skinny from the back. What's a nice tire size to meet visual and speedo functional needs? I will be running Cooper Radials and want it to look close to factory stock, NOT a hotrod look. P225/60R15's? Then I can take my 5 DF rally's and evaporust them and install Good Year E-70 15 's, and be ready for shows... Danny
check this out:http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=7&s_kwcid=AL!3756!10!3780142808!30251388067&ef_id=VSR17QAABGXq1r7H:20150408002725:s
also search on Team Camaro, lots of info on this topic
just copy then paste in your browser.
I tried it and got this on google.
Your search - http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=7&s_kwcid=AL!3756!10 ... - did not match any documents.
Try this. :)
Click ME!!! (http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=7&s_kwcid=AL!3756!10!3780142808!30251388067&ef_id=VSR17QAABGXq1r7H:20150408002725:s)
Hey Danny can you post a pic of your DF wheels before and after the evaporust. thanks
Try this. :)
yup, that's the site
