Camaro Research Group Discussion => General Discussion => Topic started by: 69ZX77MP on November 12, 2014, 01:09:26 AM
does anyone have a picture of an original power steering rag joint I have two different ones want use the correct one thank you
I have the other side if you need it. Bolt had a lock tight material
Thanks if you could post other side that would be great
Other side. I didn't add any of the marks. Just cleaned it
Thanks mine doesn't look like yours I guess I have to keep on looking thanks again
Isn't there a difference between manual vs. power steering rag joints for '69? I thought the spline area varied between the two.
69ZX...what does yours look like now?
This is what I have
I think you are fine with the power steering joint you have. I just checked a '68 power steering box off a Camaro in the shed and it has the exact one you have including the ground wire and the area with no splines towards the center. The one Bill posted looks like a manual joint, which has the area with no splines towards the side. I also have a manual steering joint and its the same as Bill's.
Can't believe I missed the power steering part! Very sorry. Mine is manual
Thanks Bill ,Mike for your feedback this site is awsome
