Camaro Research Group Discussion => Decoding/Numbers => Topic started by: Alan on November 12, 2005, 09:45:18 PM
I recently purchased a 69 RS Z28 "clone". The # on the block reads "V093DZ". I am sure the car is not a Z28 but could this be a 302 block?
Well, there's a digit missing from the date, so that should throw up a flag. Pictures are worth a thousand words, especially on stamps and trim tags.
There's no such thing as a "302 block" - 302's used the same 350 block as millions of other Chevy cars and trucks; just had different crank, rods, and pistons installed in it. If the question is "is this a real DZ-stamped block?", probably not, especially with a 3-digit date stamp.
Your right John Z,
I did not phrase that correct. I guess what I meant to ask is could this "motor" be a 302 with that casting #. It appears that I did not get all of the #'s so I will look a little harder. From what I read on the CRG website, the DZ would indicate a 302. FYI I believe that the 302 is a 327 block with a 283 crank according to CRG.
Thanks for the reply.
Guys,
I have looked again and I can not be sure if there is another # or not. After looking again it appears to read V0913DZ. Is there somewhere else I can look besides down by the oil filter? I am new to all of this and am trying to learn as much as possible. Please pardon any dumb questions that I may ask. Thanks for the help!
Alan
Unbolt the alternator (unbolting the bracket can be easier) and snap a pic of the #'s. That will tell us a lot more.
Also, the casting # on the rear of the block would be helpful.
Alan,no such thing as dumb questions.If the engine is still in the car it might be tricky to see the casting #.look behind left hand head on the block.
sebastien
Alan, take the inspection cover off of the bellhousing. If the crank flange has a single v-notch it is a 302 crank. One clue to look for.
Whats the VIN and the build date (trim tag code) on the car? Could be a real early or real late car. Since you know of the V0.... code on the engine pad, I'm guessing there is no VIN in the same area, which would lead to it being a late car.
Like mentioned earlier, the casting # on the back of the block would help also. If theres a VIN near the oil filter area, it will most likely be very tough to read, especially with the engine in the car.
Also, what is the trim tag info?
dave
Your right John Z,
im new to all this as well but from what ive found the 302-327-350 were all the same block no matter how you slice it. 3970010 on the back drivers side of the block could designate any one of those motors. The best way i found to see this was to take a drop light and lay it back by the distributor and then put your head around the brake booster. It gave me the clearest view of the casting without removing anything.
good luck
matt
Hey RamAirDave,
Was on vacation last week. Thanks for the response. Here is the VIN and the trim tag info.
VIN# 124379N685148
Trim Tag Info
ST69 12437
NOR130231 BDY
TR 716 53 CPNT
12A
Alan
Ruh-roh.
Block doesn't match the tag which doesn't match the VIN.
That's not good. One of the tags has been swapped. Can you find the partial VIN (see http://www.camaros.org/numbers.shtml#PartialVIN)?
Major red flag..... :(
Kurt,
I will check the partial VIN again. Can you tell me a little more about where the conflict is in the #'s is. I know the engine is not original but I am confused about the tag issue.
Alan
Unable to read all of partial VIN. All I can make out is 9N685???. The rest of the #'s are not legible.
At least it appears the VIN is on the original car.
VIN is from Sept 69, tag is Dec 68. The trim tag came off of a different car.
Now here's the twist. That engine could be original to the VIN.
Harder to prove without the trim tag, but....
Three things first: get me a pic of the pad and I'll take a look at it.
Is there a VIN by the oil filter?
What's the axle code? http://www.camaros.org/numbers.shtml#RearAxleNumbers
From what I can read the axle code is BG0219G2 with an E under it. Casting date, I think, is B79. I will get you a picture of the tag in the next couple of days. The VIN by the Oil Filter is not legible. Trans reads PNM22.
BG isn't a good 69 axle code. BS? But that axle isn't original to either the tag or the VIN. Is it a 10 or 12 bolt?
The picture of the pad will help. And the VIN by the oil filter is the key evidence that's missing. It is hard to see in the car.....
The N in the trans code should be a number. No VIN stamped near that code?
LET'S START FROM THE BEGINNING. YOU HAVE A COWL TAG DESIGNATING 1ST WEEK OF DECEMBER BUILD (12A) AND A NORWOOD SEQUENCE OF 130231. YOUR VIN IS 9N685148. 1969 WAS A LONG PRODUCTION YEAR WITH BUILDS IN DEC. 68 AND DEC 69. YOUR VIN SEQUENCE IS CAR NUMBER 185148 (STARTS AT 500000 FOR 1969. THIS JIVES WITH THE DECEMBER 69 BUILD (CHECK OUT PRODUCTION TOTALS IN YOUR RESEARCH). YOU SAY YOU CAN SEE A PRTIAL VIN DOWN LOW WITH N685???. IF YOU LOOK AT YOUR VIN THESE NUMBERS ARE PRESENT, THIS COULD BE REAL IF YOUR OBSERVATIONS ARE TRUE AND CORRECT. THE ONLY ODDITY I FIND IMMEDIATELY IS THE ENGINE WAS BUILT IN SEPT AND CAR BUILT IN DEC. THIS IS QUITE A SPREAD IN DATES, BUT NOT IMPOSSIBLE. DON'T FORGET, A LOT OF THESE ENGINES WERE BUILT AND 1970 INTRODUCTION WAS POSTPONED FOR A WHILE. ENGINES BUILT FAR AHEAD OF SLATED Z-28 ORDERS COULD BE VERY POSSIBLE IN THIS CONFUSING NIGHTMARE OF GM DEVELOPMENT. DON'T MISS THAT THESE CARS WERE BUILT IN NORWOOD AND LA (VAN NUYS). THE NOR SEQUENCE OF 130231 ALSO JIVES. LASTLY, THE REAREND IS NOT A BIG DEAL, LOTS OF THEM BROKE. NO AXLE HAD VIN NOTATION ANYWAY. HOPE THIS HELPS, ALL OF THESE ANSWERS CAN BE FOUND WITHIN THIS SITE WITH A LITTLE PATIENCE. DAVE
Nope - the last '69 build week was 11A (November), and his 12A tag doesn't belong on that car - it's been swapped from a December '68-built car.
Please turn off your Caps Lock key - makes your post hard to read, and caps are considered as "shouting".
