Camaro Research Group Discussion => Decoding/Numbers => Topic started by: jack on August 03, 2014, 01:15:03 AM
HI,
I have notice that the application code for the booster stamped on a tab on the top right of the booster is 2083 for my Camaro 1969. The Julian date is stamped on the other side of the tab is 1942. My code should be 9204, having disc brake in front.
My booster belongs to which car? Julian Date 1942, can that be?
Please see picture of tag with application code. You will notice that the code is stamped up-side-down.
I would think 71-72 Nova w/ discs, which would explain a 194 of 2 Julian date. Speculation at this point -
Regards -
Hi
I found that the application code is 1942. This was for a 1971-1972 A-Body. SO I will be replacing mines for a 9204 booster.
There are many on the market. What will be the best date be for a camaro 1969 12D Norwood?
Is a date code 311 or 321 better?
Either would probably work, although they both are a ways out. Read this:
http://www.camaros.org/forum/index.php?topic=9416.0
There are lot of threads devoted to boosters here - search "brake booster" and you'll see a bunch of discussions -
Regards
The article helped a lot... I will look at a date between 330 and 345...
Take Care
The 9204 booster on my 05A car is dated 120.
HI,
I have an 02A 69 Z/28 and my booster is 356 Dec 21 1968
Jack, If it helps any I have a 12B built Camaro with a booster dated 330 (Nov.25)
My 69Z is 12D Norwood just like Jacks. Still has it's original booster I could get the date from if it helps, but his post is nearly a year and a half old, I'd guess he probably replaced it by now.
Hey you never know. If he's anything like me he could be still looking. And it's always good data for the next guy researching this topic.
Okay here ya go,
9204 booster and dated 356
Good point...
02C Van Nuys built '68 Z/28: 9078 brake booster dated 343 (December 9, 1967).
Thanks Guys
and Thank you X33RS. Wow your Brake Booster was built close to the built of your car.
Sorry for the delay, I had to put my SS on the side for a while for family reasons...
Jack
Thanks Guys
Jack
While we are at it...12B 341
