Camaro Research Group Discussion => Originality => Topic started by: llskis on June 08, 2014, 09:29:08 PM
Title: Need help/picture to correct my 69 Z28 write up from Jerry MacNeish.
Post by: llskis on June 08, 2014, 09:29:08 PM
Have a 1969 Camaro Z28 that has been certified by Jerry MacNeish. One of the corrections that need to be done that was
reported in the certification was: "Lower Rocker Area should be painted semi/gloss black below the rocker molding". Car was
repainted years ago and all that area was painted "Hugger Orange" the original color. Enclosed is a picture of the area. Can
someone please post a picture how it should look? What kinda black should be applied. Eg. like Rustoleum 7777 or ??. Please
comment on this. Thanks--Larry
Title: Re: Need help/picture to correct my 69 Z28 write up from Jerry MacNeish.
Post by: janobyte on June 08, 2014, 09:57:25 PM
Do a little searching on the site, there are some good threads on proper finish ( % gloss) and were to mask off to get it correct. Seems like it was a hot topic a few months ago. Assuming RS package ?
Post by: llskis on June 08, 2014, 10:07:14 PM
janobyte: No RS package; standard Z28. Thanks; Larry
Post by: Danzo on June 08, 2014, 10:53:46 PM
With the Z21 exterior style trim group.
Post by: cook_dw on June 09, 2014, 12:30:57 AM
(http://img.photobucket.com/albums/v687/superslow/1969%20Frost%20Green%20Z28/DSC03220_zps3fe31f67.jpg) (http://smg.photobucket.com/user/superslow/media/1969%20Frost%20Green%20Z28/DSC03220_zps3fe31f67.jpg.html)
(http://img.photobucket.com/albums/v687/superslow/1969%20Frost%20Green%20Z28/DSC03233_zps8f40232d.jpg) (http://smg.photobucket.com/user/superslow/media/1969%20Frost%20Green%20Z28/DSC03233_zps8f40232d.jpg.html)
Post by: llskis on June 09, 2014, 05:39:15 AM
janobyte: Have tried search but coming up MT; can not find the wording of that thread so search would work. FYI  Larry
Post by: janobyte on June 09, 2014, 11:39:28 AM
try "rocker panel paint" , under this heading are the threads I'm thinking of that might help--steve.
Post by: janobyte on June 09, 2014, 11:44:05 AM
Cook may have already answered your question with his 69 pic.
Post by: llskis on June 09, 2014, 11:58:42 AM
Yes; thanks to Cook DW for picture. Did find some info on the "Search". Type of the color Black is still in question. To me it looks like a
Satin Black. (Like Rustoleum 7777) Will go with that unless I hear different. Larry
Post by: Mike S on June 09, 2014, 12:56:27 PM
 I don't think you can do any better than GM Reconditioning Black as far as matching the correct gloss level and texture goes.
Post by: firstgenaddict on June 09, 2014, 02:17:47 PM
It's really not a semi gloss, Here is an untouched unexposed place on a 69 SS showing there is a reflection and a good bit of gloss.
(https://lh4.googleusercontent.com/cdSJb9771jY27_FSXmkDAuQw1aQXfH8ffQJXW9ulnPw=w941-h617-no)
Post by: sbmiano on June 09, 2014, 05:20:36 PM
Its not really semi gloss but more of a flat gloss.  The black should end underneath the chrome rocker trim about in the middle.  I went through this when my car was certified by Jerry and it has been at the nationals last year with the correction that was done approved.
Post by: 69Z28-RS on June 09, 2014, 06:08:12 PM
I agree with Mike S....    GM reconditioning black will be good for that area.. :)
Post by: ZLP955 on June 10, 2014, 02:25:57 AM
Here's a good previous thread on the same subject:
http://www.camaros.org/forum/index.php?topic=10687.0;all
Post by: llskis on June 10, 2014, 11:59:07 AM
This project is turning out to be more complex then what I thought at the beginning. Here is a few loose end questions for our members.
1) I assume that all trim is to be taken off like the trim around the front wheel wheels and the chrome rocker trim; correct?
2) All bolts should be removed before the paint; correct?
3) Hard to tell by pictures given but the black on the panel (where the panel turns horizontal) is consistent throughout. This means
    when the factory done it the body of the car was up in the air. If car was down lower I would assume the black paint would
    be heavier on the end then lighter as it gets towards the frame. Correct? If yes then a "lift" would be needed to do the job.
All comments are welcomed and thanks.  Larry
Post by: cook_dw on June 10, 2014, 12:17:51 PM
1 &2) Yes trim & bolts need to be removed and the line will almost split the spear bracket screw holes.
3) Depends.  If the car was from NOR then will probably will not see as much overspray on the underside of the car due to it being just a few feet off the ground and truthfully the fenders would come off as well to do the spray on the lower cowl or tulip panel area as seen in James' photo.
    If it was built in LOS then you would have more (or should I say potentially see more) overspray due to it being held from an overhead conveyor system.
Also remember that the subframe, brake lines, etc would not have been there when this was painted.  If I were doing this I would tape off on the inside weld seam lip and spray that area.  Removing fenders to get that area covered would be up to the individual.
Someone please correct me if I am wrong.  :)
Post by: ko-lek-tor on June 10, 2014, 12:49:37 PM
3) As I understand, facing the side of the car, the black was sprayed perpendicular to the body side. This would mean the part of the rocker that turns under (faces the ground) did not get directly painted, just overspray. Will point out that Norwood blackout done by Fisher, so fenders were not on the car and posted and known examples show a masked line on lower cowl usually tappering upward toward front of cowl. Not imperative in resto, but exact.
My car as an example of masked front cowl (ignore the rust and flaws).
Post by: JohnZ on June 10, 2014, 03:10:49 PM
Remember that the rocker panel was sprayed black in the Fisher Body main Paint Shop, when the body was just a shell, prior to entering the Fisher Body Trim Shop. The matching black on the bottom of the front fender was sprayed in the Chevrolet front sheet metal Paint Shop on their side of the plant, hours before the fender was installed on the car.
Post by: ZLP955 on June 11, 2014, 03:21:13 AM
How did that process differ at Van Nuys John?
Post by: JohnZ on June 11, 2014, 02:38:09 PM
Van Nuys had converted from Fisher/Chevrolet to GMAD the previous year, and had consolidated the Paint Shop (eliminated the Chevy paint shop); the front sheet metal previously painted separately by Chevrolet was now mounted on conveyor bucks about five feet ahead of the body shell. The black rocker and fender areas were masked and sprayed at the same time, but it was many hours later before the fender was installed on the body.
Post by: ZLP955 on June 11, 2014, 10:39:59 PM
Thanks John
Post by: Oaklyss on June 17, 2014, 02:14:19 PM
(http://i145.photobucket.com/albums/r206/OAKLYSS/69%20SS%20detail%20shots/leftrearrocker.jpg) (http://s145.photobucket.com/user/OAKLYSS/media/69%20SS%20detail%20shots/leftrearrocker.jpg.html)
(http://i145.photobucket.com/albums/r206/OAKLYSS/Sell/DSC02700_zps082cea05.jpg) (http://s145.photobucket.com/user/OAKLYSS/media/Sell/DSC02700_zps082cea05.jpg.html)
(http://i145.photobucket.com/albums/r206/OAKLYSS/Sell/DSC02707_zps830f7f46.jpg) (http://s145.photobucket.com/user/OAKLYSS/media/Sell/DSC02707_zps830f7f46.jpg.html)
(http://i145.photobucket.com/albums/r206/OAKLYSS/Sell/DSC05773_zps8ce78c93.jpg) (http://s145.photobucket.com/user/OAKLYSS/media/Sell/DSC05773_zps8ce78c93.jpg.html)
Post by: firstgenaddict on June 18, 2014, 03:42:09 PM
Those are GREAT pictures!
Post by: 69Z28-RS on June 18, 2014, 06:55:51 PM
I don't know how the rocker was painted as well as that one was, without getting any black on the vertical seam rib below it..  unless a mask was used?
Post by: llskis on June 18, 2014, 10:21:16 PM
Holy Cow; I'm more confused now then when we started. Are they all correct? I was going to do this project myself; not
now. Will hand this job off to the pros in the painting dept. Don't know which pattern I'll do. Larry ???
Post by: Oaklyss on June 19, 2014, 12:41:18 AM
Van Nuys was different then Norwood. They must have used something, because the bottom just got body overspray. Original paint car.
(http://i145.photobucket.com/albums/r206/OAKLYSS/69%20SS%20detail%20shots/wellandblackout_zpsf045e8f1.jpg) (http://s145.photobucket.com/user/OAKLYSS/media/69%20SS%20detail%20shots/wellandblackout_zpsf045e8f1.jpg.html)
(http://i145.photobucket.com/albums/r206/OAKLYSS/69%20SS%20detail%20shots/floor.jpg) (http://s145.photobucket.com/user/OAKLYSS/media/69%20SS%20detail%20shots/floor.jpg.html)
(http://i145.photobucket.com/albums/r206/OAKLYSS/Sell/DSC05655_zps91b5ebed.jpg) (http://s145.photobucket.com/user/OAKLYSS/media/Sell/DSC05655_zps91b5ebed.jpg.html)
Post by: ZLP955 on June 19, 2014, 08:41:52 AM
Oaklyss, in that last picture, is the horizontal area on the underside of the rocker bare metal? Can't tell, could be the flash effect, but it looks like there isn't even primer on there.
Post by: janobyte on June 19, 2014, 10:42:25 AM
Good point is they were not perfect. Above my fuel tank was basically bare metal, "mist" of primer. Good representation Oaklyss. I've posted before ,ironically, more time was involved trying to replicate "factory" vs. "over restored"  in mine anyways.
Post by: cook_dw on June 19, 2014, 11:40:08 AM
I think you are getting the flash along with the orange reflecting on the black giving it that bare metal look.  You can see the line where the black ends (or the bare metal looking area) and orange begins.
Post by: ZLP955 on June 19, 2014, 11:59:12 AM
Yes but I asked the question because if you look at picture 1 in reply # 21, it looks similar, but without so much possible H.O. reflection.....
Post by: cook_dw on June 19, 2014, 01:33:02 PM
Gotcha.  Thought it was from his last post.  It does look like bare metal.
Post by: Oaklyss on June 19, 2014, 02:31:54 PM
Not bare metal, just the flash. Heres a better photo. You can see the paint line:
(http://i145.photobucket.com/albums/r206/OAKLYSS/69%20SS%20detail%20shots/ec193a4e-5bb8-4328-8a63-bbcbd7ed4e4c_zps03a3a0c5.jpg) (http://s145.photobucket.com/user/OAKLYSS/media/69%20SS%20detail%20shots/ec193a4e-5bb8-4328-8a63-bbcbd7ed4e4c_zps03a3a0c5.jpg.html)
Post by: ZLP955 on June 19, 2014, 09:55:30 PM
Great, thanks for confirming, and for that last photo. Definitely appears that the rocker was masked off by the VN workers before the black was applied, way to neat of a line between the two otherwise.
