Camaro Research Group Discussion => Originality => Topic started by: Bryan302 on June 02, 2014, 01:11:43 AM
What original tires did early 1968 Z/28's have? Is it possible for October, November, December 1967 built cars to have red or white stripe Goodyear E70-15's? What is the earliest know Goodyear Wide Tread GT on a 1968 Z/28?
Bryan
That's a good question. In the 67 Z road test article, the test car had white stripes.
No production Z's had white stripe tires.
In that case, did striped tires quit at the end of 1967 Z/28 production, and Goodyear WT's start at the beginning of production of 1968 Z/28's?
Bryan
What was the P28 option, priced at $90 for 1968 models,... "Wheels, 15" and special tire (added 03JAN68 to AIM)"
Bryan
That's a good question. Someone here may know more about it, but I think the red stripe tires ended with the last 67 Z and the wide treads started with the first 68 Z.
There is a guy on the Yenko site with a 68 L78 4.56 or 4.88 car that has the original window sticker and 15" tire option, pretty sure it has DF's & wide tread GT's, someone else remembers a car (was def not a Z as it either had air or was a real auto car) with the 15" tire pressure sticker but had discounted it as being wrong earlier in their life.
Would the wide tread GT have been called a 'special tire' in Jan '68? Was that the standard tire on the Z28 at that time? If not, what WAS the standard tire on the Z28 in Jan '68? I was thinking that this 'special tire' might have been red line tires...?
It was an E70x15 according to the air pressure sticker, being available only on the Z28 I would call it special.
By the way the early 69 Z's list the on their Window Sticker a no cost 15" tire option.
PU6 AD - E70 x 15 Tiires
This was dropped sometime between N522xxx and N528xxx based on the Window Stickers in JM's book.
I have an original Goodyear wide tread tire still on the large font DF wheel and the tire is date coded Jan68. JerryM 68 survivor is an earlier 67 built 68 Z so maybe he will chime in.
If a SS got this option, what would the spare tire be?
It has to match the other 4 road wheels.
Thanks, sorry I wasn't more clear. I'm sure the spare would be a 15" if that's what you mean by "match", but would it be a regular or rally rim. In otherwords, did P28 include 5 rally rims & 5 RWL tires or would it have been a 15" regular rim whitewall spare?
Typically, all five tires matched *unless a space saver option were selected*. This was true even in cases where the spare tire was mounted on a 'regular' rim rather than a special rim if so ordered. I'm speaking of the automotive industry in general during those days, as opposed to Chevrolet specifically in 1968...
For all applications (except Space-Saver), all five wheels and tires were the same; only the trim pieces (center hubcaps, full wheel covers, and trim rings) were four to a car.
whats the best deal on e70 15 wide tread gt's?
On the yenko site is a guy named Rusty that goes by small hurst. I think hes an advertiser now. About as good as deals as you find
