Camaro Research Group Discussion => Maintenance => Topic started by: x77-69z28 on May 19, 2014, 03:34:29 PM
My 67 RS/SS with console gauges fuel gauge has stopped working. Any ideas? I think it is a ground problem as it is pinned fast full. Yet, I ran out of gas!
Buddy
check the ground ,only problem I ever had was once in a great while had to clean the ground by the tank. Use a little dielectric grease. Still retains the OE sending unit which works fine. Into a 46 yo S.W. gauge.
Yes, hopefully it's just the ground as janobyte describes... I went through this a few months back and discovered that I was not so lucky.. the Fuel sending unit in the tank had gone bad. Here's my post troubleshooting this. http://www.camaros.org/forum/index.php?topic=11830.msg96919#msg96919
Hope this helps, Ed
Yes - check the sender ground first. You can troubleshoot the sender, harness and gauge following the troubleshooter over at TC: http://www.camaros.net/forums/showthread.php?t=195833
Thanks guys, I will let you know how I make out.
