Camaro Research Group Discussion => Decoding/Numbers => Topic started by: Danzo on May 09, 2014, 06:01:59 PM
Any info on these 2 VINs 124379L516132 124379N514559
Thanks in advance.
Yes N514559, no L516132.
9L516132...
http://www.camaros.net/forums/archive/index.php/t-133268.html
As for that discussion RS can easily be undetectably retrofitted to a Camaro.
If you pull the back up lamps you can tell if the cutouts were punched or if they were sawn, ground, & filed, this would be the most difficult original thing to replicate...
William, what info do you have? Thanks.
My original Z/28-RS had the rear body panel replaced during the restoration as did many Z11s.
Kurt is the keeper of the db. I'm sure he will address this.
Car was on ebay earlier this year in CA.
Restamped block, IMO.
