Camaro Research Group Discussion => General Discussion => Topic started by: BillOhio on March 03, 2014, 01:13:23 AM
Title: eBay picture
Post by: BillOhio on March 03, 2014, 01:13:23 AM
Check out the writing on the side of the tire.
Same car, should the driveshaft be this crooked? Never noticed before
Title: Re: eBay picture
Post by: BULLITT65 on March 03, 2014, 01:37:30 AM
I see the comments " bent wheel use on rear". For the drive shaft I think the reflection of the exhaust pipe on the shaft gives a perception that it is at more of an angle than factory, but upon closer inspection it looked ok i think.
Post by: Mike S on March 03, 2014, 01:39:34 AM
Looks like the rear is definitely skewed. Are the axle tube mounts sitting on the spring tits for centering?
 I am only use to seeing mono springs with metal tits so I assume multi's have them too.
Post by: BillOhio on March 03, 2014, 01:48:51 AM
Just noticed, first picture shows the shock bolt I have been asking about
Post by: 69Z28 on March 03, 2014, 02:14:22 AM
Just curious but does the multi-leaf's come with the emergency brake line holder? I always thought that was a mono-leaf part.
Post by: Mike S on March 03, 2014, 02:19:27 AM
  I think you are right about the reflection. I know from experience that it's damn near impossible to skew a rear on the springs providing the axle brackets are of the correct width.
Post by: BillOhio on March 03, 2014, 02:42:00 AM
There's a holder on multiple leafs also
Post by: 69Z28 on March 03, 2014, 03:05:25 AM
Damn....now I need to check if I have them. I had to find the plates when I first bought the car because I took of the slapper bars. Always learning something.
Post by: 69Z28 on March 03, 2014, 03:50:59 AM
I don't think those are what's on the multi's though are they? I'm thinking they are different then the mono. I can't find a pic with any like whats on that car in the pic.
Post by: ZLP955 on March 03, 2014, 06:42:31 AM
If that is the same car I'm thinking of (ebay), the spare wheel in the trunk has taken a big hit too - the wheel rim is visibly bent. Just don't understand how people include pictures like this in a sales ad, but then again, are they unaware, or just (silently) disclosing issues?
Post by: BillOhio on March 03, 2014, 03:09:54 PM
I think the cars Burgandy, listed for 54,900. I had ricks catalog handy and it says the bracket is for both sides multi leaf and rh side mono
Post by: 68Zproject on March 03, 2014, 03:49:48 PM
If you look down the tunnel you can see the driveline is straight.  Just bad photography.
Post by: sixt9x33rs on March 07, 2014, 12:20:24 PM
They are all the same. The factory e cable support has a "W" stamped on the end of them. I don't know if the repops have that same stamp. If you need a picture of it send me an email.
Post by: 69Z28 on March 07, 2014, 04:48:50 PM
Figured it out that they are the same, part number 3923533. Unfortunately mine are missing so I need to locate a set. Anybody have 2 extras?
Post by: 69pace on March 08, 2014, 06:37:23 PM
Anybody have the link to the ebay ad?
Post by: 68 Ragtop on March 08, 2014, 09:03:52 PM
It is normal to have this slight skew in the drive shaft because the pinion is not centered in the rear end.
