Camaro Research Group Discussion => Restoration => Topic started by: sbmiano on February 23, 2014, 12:29:59 PM
Title: power steering leak
Post by: sbmiano on February 23, 2014, 12:29:59 PM
i have a leak from the back of the pump. It is leaking from the gold nut in the back.  I have tried to tighten it but it continues to leak.  Any suggestions?
Title: Re: power steering leak
Post by: big iron on February 23, 2014, 08:58:35 PM
Could be the flare one the high pressure hose is damaged or the seat where the HP hose is secured.  Could be the seal under the nut, between the pump and the can.
Be warned that replacement hoses are not correct and power steering pump cans are date coded.
Bob
Post by: JoeC on February 26, 2014, 04:50:44 PM
Chevy parts dept had a kit with all the seals ,gaskets, and o rings to reseal the PS pump
I don't know if they still sell it but try GMpartsdirect or other online GM parts source
