Camaro Research Group Discussion => General Discussion => Topic started by: my124677n on February 03, 2014, 10:16:48 PM
I need a black oil fill tube for a '67 327/210 hp, without the threaded hole for the pcv valve. Issue I am facing is that I have an original AC Delco push-in breather cap, so I need the filler tube that allows a push in breather, not the screw on type. Any info would be appreciated. Thanks!
Do you have a photo of the one you need?
Don't know if this is the one you are looking for...
http://www.ebay.com/itm/1955-1967-Chevy-Oil-Fill-Tube-N-O-S-/251436276381?pt=Vintage_Car_Truck_Parts_Accessories&hash=item3a8ac51a9d&vxp=mtr
Part #3711724, NOS, auction ending in 1 hour!
My original does not have the step that the eBay one has.
I was going to bid, but could not see the top of it to see if it was the twist on type. I thought the original 67 that did not have the PCV valve up front on the filler tube should have a push in type filler tube. Still looking....
Found it.
http://www.johnsclassiccars.com/parts/detail_view/Parts/Camaro/11
Congratulations! After seeing the one in the auction on eBay, I remembered I had something similar on one of the intake manifolds I pulled off Camaros in the good old days. I took a couple of iPhone photos this afternoon. Sorry about the shadows, it's sunny out here in California! Warm too! ;)
Is the fill tube with the return spring tab proper for a 1967? Or di the 1967 use a smooth tube without the return spring provision?
Looking at the AIM it appears a smooth, non-tabbed tube would be correct
Anyone know what the correct application is for the oil fill tube pictured in reply #6. It is on a '67/68 Z28 intake manifold and I know that is not correct.
Mid 60's fullsize..??..
(http://img.photobucket.com/albums/v687/superslow/65Impala2007engineltfrt_zps7e98dc0d.jpg) (http://smg.photobucket.com/user/superslow/media/65Impala2007engineltfrt_zps7e98dc0d.jpg.html)
I think that Intake could possibly be an L79 Intake, and for certain applications would have had that Oil Fill tube.
I believe the Camaro had a smooth tube, and has been stated without the extra "step".
Here is a link for the one pictured in reply #6;
https://www.impalaparts.com/product.php?productid=5867OFTBB
used on '58 to '67 Full-size, and maybe some others.
Thanks guys! That looks like the one.
Nope, it's definitely a Winters' 1967-68 Z/28 intake manifold (casting number 3917610).
[/quote
Paul, I have a #3917610 on my car, and I have seen #3890490 (L79) Intakes are both Winters Foundry. There are other differences, in other areas both are very similar in this area. I am wondering with the quality and size of these pics. how you can be so sure? I'm not saying your wrong, just wondering. I don't see anything that definite.
Mike, I have the above (and now below) pictured manifold in my garage. I pulled this one off a wrecking yard '68 Z/28 back in 1982, I just didn't know why someone changed the oil fill tube.
P.S. I apologize for the lousy iPhone photo.
No harm Paul! As I stated, I could not see anything that definite from the other 2 pics.
My early production '67 (L30) has no step in the tube (other than the portion that goes into the intake manifold), and no tab for the return spring. Sorry I am not near the vehicle for pics. Hope this helps.
