Camaro Research Group Discussion => General Discussion => Topic started by: camaroman1969 on October 29, 2013, 12:33:00 AM
Does someone know when factory installed radio antenna on rear quarter panel ?? Thanks! Don
My 12E '68 came with one.
Jim, What kind of radio is in your car?? AM/FM stereo?? Don
My 5E 67 has it. The rear antenna option was available in 1967 and was for AM only. Not sure of 68 or 69 if it was still limited to AM.
AM
I know of 2 68's both originally AM radios, both non spoiler cars & one was rear & the other was front.. So I'm not sure there was a standard for non spoiler AM cars...
All spoiler cars were front fender regardless radio
AM/FM were front fender
AM with no spoiler I've seen both ways...
My 68 Camaro convertible with 250c.i. 6 cylinder, with manual steering, manual drum brakes, non-spoiler car had an antenna on the passender rear.
When optiion U73 was ordered: antenna, manual, rear mounted, (AM only).
The Options PDF (http://www.camaros.org/pdf/options.pdf) is always helpful on those kinds of questions. Also look at D80 about the spoiler issue.
My 12D 68 does have U73.
Or are we all mistaking your question? Do you mean when it happened in the assembly process?
Yes, that my question, When was a rear antenna installed at factory?? When option "U73" was selected? I would assume. Thanks
Yes, that my question, When was a rear antenna installed at factory?? When option "U73" was selected? I would assume. ThanksThe Options PDF (http://www.camaros.org/pdf/options.pdf) is always helpful on those kinds of questions. Also look at D80 about the spoiler issue.
Obviously, when the order specified U73, the plant installed it; Fisher Body installed the front-to-rear antenna cable in the body, and Chevrolet drilled the hole and installed the antenna base on the rear quarter panel.
My 03 1967 has U73 and rear antenna on passenger side.
J.R.
My Survivor 69 Z28, built 10B, 1968, has rear antenna, it shows as an option on my original paperwork for $9.50,, has the original AM Radio that works great
My 68 z ( no spoiler originally from factory ) had it in the rear build date : 4th week in April.
I can only imagine that they wanted the aerial for am/fm to be front fender mounted, in order to keep the aerial lead as short as possible for least signal loss at fm frequencies.
Yes rear antenna takes preference over spoilers, if you ordered both you got the antenna and no spoiler.
Actually, if you ordered both, the order would have been rejected at the order edit stage at the Zone, and returned to the dealer for correction and re-submission.
Thats interesting... The story I received about the low mile early Z28 I have is that the spoiler was ordered, when it was delivered and wasn't so equipped so the dealer installed it one after delivery. Could have been the dealer didn't tell the customer about the lack of harmony in regards to the order and just added it.
Does your car have both the rear antenna and rear spoiler? Does the spoiler his the antenna when the trunk is raised?
It did however no longer is so equipped since being restored.
And yes with the antenna up they do interfere with one another.
Becomes second nature moving antenna to one side before opening/closing trunk. I was told spoiler was installed at dealer , had assumed it was over the counter. My thoughts have changed per JohnZ's response about priority in assembly.
I bought a SS in 1979. It had the rear antenna and spoiler. I was 16 at the time and didn't even keep any info on the car. I believe it was an early production. The interesting thing is it was the short spoiler. I don't recall it ever hitting the antenna. No idea of when or where the spoiler was installed.
