Camaro Research Group Discussion => General Discussion => Topic started by: jphill2480 on October 09, 2013, 06:21:03 PM
I have a 67 Camaro and I have a question about the dashboard. I have a hole to the right of the steering column and below the iginition switch. I was wondering if anyone knows that this may be for? I wondered if there is a possibility that it may have been for a manual choke cable as the carb does not have an electric choke. I know the original engine has been replaced with what I was told is a 350 V-8 from a 69 Chevelle so I am not sure what this hole may have been used for. At the top of the right side of the steering column is where a cigarette lighter / power supply is located, then the next item down is the iginition switch, and this hole. On the left side of the column is the light switch and the windshield wiper control.
I am anxious to learn what this hole is for and I have not been able to locate any pictures of a 67 dashboard to see if that would help.
67 nor 68 had a hole below the ignition switch. If this hole was for a manual choke it was installed by a previous owner. They came with a thermostatic choke take worked off of heat from the intake to open it.
FYI when you have questions about your car or anything in general pictures are worth a thousand words as they say. In some cases it helps greatly..
(http://img.photobucket.com/albums/v687/superslow/1967%20Camaro/DSC02677_zpseb16a652.jpg) (http://smg.photobucket.com/user/superslow/media/1967%20Camaro/DSC02677_zpseb16a652.jpg.html)
My 68 Z had a hole there. I added it. I put a backup lite switch there since the switch on the Muncie was not working.
1967 Yenkos had the tach mounted below the ign switch
I have seen some with aftermarket manual choke cable there
also maybe an aftermarket fog light switch
Let me correct my comment..
67 nor 68 had a hole below the ignition switch from the factory..
;D
Nope. No Camaro ever had a manual choke from the factory.
X2 on Darrells reply, Neither 67 nor 68 had a hole there.
