Camaro Research Group Discussion => Mild Modifications => Topic started by: sdkar on October 08, 2013, 06:49:36 AM
I am looking at pics of a parking light from a 71 Cutlass and they appear to look exactly like those from a 69 Camaro. The only difference seems to be the lenses have a larger brow, but the main assemby looks identical. Does anyone know if these are the same?
I doubt it - different car divisions hardly ever shared any appearance parts.
Only one that I have ever heard of parts being used (that were at least similar) was the 70-72 cargo light on the C-10 and the 69 RS backup light housing. Of course the pigtail was different..
Could it be a common housing with a different lens ?
They sure look similar, although as you say, the lens looks slightly different:
http://www.opgi.com/cutlass/C240932/
(http://www.opgi.com/common/C240932LH-lrg.jpg)
The Lens is not the same however it looks as though the housing is close, even the pigtail looks right... a Hollanders might list the interchange.
The bases are the exact same. The lenses look similar, but the Cutlass has a larger "brow", and would stick out. However, the bases will work.
Thanks for the confirmation.
