Camaro Research Group Discussion => Originality => Topic started by: DT on September 28, 2013, 08:09:39 PM
Anyone know what the correct GM part# is for a 69 (Rosewood) 4 speed shifter console plate?? There appears to be 2 different part #'s ? ??? 3921801 and 3949537
Checked the 2 original plates I have, the part number cast on on them is #3949537.
Thanks Copo.
Here's mine:
(http://i1218.photobucket.com/albums/dd420/ZLP955/1969%20Chevrolet%20Camaro%20Z28/DSCF7615.jpg)
Donny, the 69 AIM shows that plate as part # 3949537 (UPC D55, sheet A4). I believe 3921801 is the 1968 part number for the same item, so would have the simulated walnut woodgrain.
OK, thank you guys. I actually thought # 3921800 was for a 68 ? Hmmmm.
Is it possible the 69 3-speed plate has a different number?
Nope. Both 3 and 4-speeds used the same plate, as shown in the Assembly Manual; they just used different shift pattern emblems.
