Camaro Research Group Discussion => Maintenance => Topic started by: 69Z28-RS on August 30, 2013, 10:16:22 PM
Hey guys, I could sure use some help/tips from someone who has removed a '69 Camaro remote mirror bezel and cable. I need to remove my driver side door panel to adjust and lubricate my door glass mechanism, and I cannot see out how to remove the bezel from the remote adjuster; the bezel doesn't seem to fit thru the hole in the door panel.
I'm thinking there MUST be a trick, something I'm unfamiliar with and I do not want to destroy anything.. :) The only potential means to remove it that I can see is to use pliers to release the cables from the adjuster, but there are three of them, and once released (assuming they will release as I imagine), I've no idea how I would get them back into the correct location. Pictures attached for reference. Any help appreciated, and Thanks in advance!
There's a flat head set screw in the bezel itself. Loosen it and bezel will come off. (see picture)
Here's a better picture.
FANTASTIC!! :) I posted that request, and then went to dinner, come home, and Ed has the answer.. :)
Thank you very much ED!! :)
