Camaro Research Group Discussion => Mild Modifications => Topic started by: hubleyman on July 25, 2013, 02:56:19 AM
So I am just about done with rebuilding my 302 for my '69 Z and decided to change from stock exhaust manifolds to headers. I'd like the car to be louder and a few extra HP never hurts anyone. After researching all the threads I could find on the subject, it seems prudent to ask the group once again what the current best choices may be based on your experiences. Every time I see good recommendations, I seem to run across not-so-good ones for the same product.
Here are some specs on my engine:
Bored .020 over with true final 11:1 comp ratio (custom built pistons with no block decking)
30/30 solid lifter cam (Comp Cams OEM replacement)
OEM heads with no porting
OEM intake and carb (upgraded to 72 primary jets)
OEM distributor (set up per CRG recommendations)
Roller rockers and a few reliability upgrades
FYI - The car has OEM power steering.
I also plan to keep the chambered exhaust because it appeals to me. The car typically gets driven locally mostly / a Sunday-Funday cruiser. No racing or drag strips, but maybe an occasional slip of the clutch to see if the rear wheels can still smoke a little.
I'm looking for an excellent quality product, that fits properly out of the box, and doesn't require mods for my power steering. My first inclination is to go with Stahl headers, because they built me a couple of sets for my midyear Corvette race cars and were superb, but I have not used them on a street car as of yet. Also thought about buying some repro OEM style headers because that would be cool, but they seem to be fairly pricey. I've had Hookers, Hedmans, etc. on my street cars which were fine, but not great.
The rebuilt 302 goes on the dyno soon, so it's about time to order some headers. Any suggestions or comments, good or bad, from recent purchases? Any new input would be greatly appreciated.
Thanks! Charlie
Charlie, interesting to see what others recommend, but I have heard good things about Doug Thorley Tri-Y headers, especially regarding underside and engine bay clearances, so will be getting those for when I reassemble my car.
I would love to hear chambered pipes with a set of Mickey Thompson Super Scavengers but good luck trying to find a set. I run Hookers on my cars until I find the MT SS.
Hi Charlie
I have Hooker Super Comps-P/N 2131. Fit is okay-had to dimple near the p/s box on cyl. #3 tube, and at the pitman arm. I've seen some posts that state the right side header hit the idler arm. Never had this problem. Also the left collector flange hangs a little lower than the right. Just a side note- I put a set of headers and dual exh. on a 1970 z/28 I had while in college. The power difference was night and day (felt like I put a blower on it). They may be a headache to install, but are well worth the headache. Probably a true 35-40 horsepower improvement.
Good Luck
Harry
The last headers I purchased for my '69 Z28 (no PS), I had to remove the reverse lockout mechanism, which I didn't like to do, and now I'm still hunting in my shop for the lower rod that I removed at that time. and those also 'hit' the floorpan at the collector which I didn't care for.
Which available headers for a '69 302 do NOT require removal of the reverse lockout rod? and fit the best with the other factory equipment?
October issue of Popular Hot Rodding has some interesting header articles. The one describing the temperture difference of Coated versus painted really woke me up. They run much cooler.
I couldn't say what brand of header I had on my Z when I first bought it, and I still have them hanging on the wall in my garage, but I purchased a repro lower lock out rod from Rick's in 2001 and it fit with no problems and had pretty good clearance. I'm gonna go out on a limb here and say headers are headers no matter who you buy from and what coating is on it, at least for the street I would think. I don't think the exhaust gases really have any idea what they are going thru. I had so many problems with changing spark plugs and burnt spark plug wire boots I just yanked mine out and said forget this. I kind of like the day 2 look with white headers myself, if I was to change my way of thinking on headers, but I don't think I'll do that anytime soon.
I was looking thru some of my notes from the past few years and at one time on the Team Camaro site some members where going for the Summit 1 5/8", part# SUM-G9001-9 header. I haven't looked at them for a while but I think those are fairly decent and are coated I think and were going for around $210.00 last I looked.
All the input in this thread is really helpful, and I'm getting close to making a decision. My engine is done, dynoed and ready to install so it's time to pull the trigger on some headers regardless of the choices.
However, now you guys got me obssessing over those M/T Super Scavengers. I understand they're hard to find and most likely very expensive if you ever do, but I really like the design of them. It wouldn't matter if they were originals or reproductions for my usage, but they may just have to stay on the wish list until I locate a decent set someday.
Thanks for all the suggestions! Charlie
The headers on my car when I purchased it also had no clearance issues with anything, everything was in place, but after sitting for many years, they were totally rotted, so I bought new ceramic coated headers.. and they DO have clearance issues..
I think the original ones were Hedman. Are those still available? in the same design as original?
I had my 302 rebuilt and the only modifications are roller rockers, a custom grind cam, headers (hooker comps) and what ever magic the engine builder did and it dynoed @ 419 HP and 372 lb/ft of torque. I know many love the orig 30/30 (long ramps and single pattern grind) but the responsiveness of this engine exceeded my expectation. Plenty of torque with a close ratio and 373's, so drivability is excellent.
I picked flowmaster american thunder exhaust system but installed the 50 series low profile mufflers. I did this because I had the 40 series (on another car) and the resonance was too annoying for me.
were not the pipes on the mt scavengers all the same length ?
They were but did it in the collector. If you looked in the collector the tubes were ran until all 4 were equal. Someone was reproducing the at one time.
I'm running these and am happy with them. Only thing I didn't like was they sounded like they had back pressure when accelerating normally. The Hooker comps I had on previously did not. Anyway, I add an H pipe to the exhaust, and that eliminated the back pressure sound.
Steve,
1) How about some more info on the roller cam you used? source? specs? price? availability? etc..
2) Did the Hooker comps interfere with your rev LO rod?
Gary
Stahl closed the shop down I believe ....
You can still purchase from Stahl ( if in stock, also selling kits) no more manufacturing.
Gary---Lunati techs sent me the specs for a roller cam designed for a stock 302 ,M21 ,3:73 rear end. ( engine would have more bottom end thus street friendly gear) However requires larger diameter valve springs and I'm not about to have my heads cut.
Or exchange them with another set I have.
I do have a 64 327 with a set of 2.02's 64 cc heads (early castings) ,nice candidate for a future project...
We run a roller in a 400 (414) and are very pleased with the results. smooth idle and improved vacuum, HP/torque crosses at 5500. 7400 starts falling off , but still pulls on a pass,curves run parallel on the dyno .Makes quite a bit of power but no "lobe" at idle ,and no "hit". Very smooth power band. I'm sold on them. Modern technology. Just goes outside my parameters for this project. Not to say I may not have another engine on the stand for it ;)
Hey ,survive the storm ok ???
Original thread...really do not think you can go wrong with a set of tuned Hookers.
Gary,just sent you an email with the specs if your curious.
Jano,
I received your email... I like Lunati... had a lunati blueprinted 302 cam in my '67 302 race engine, but I've never used or built an engine with a roller cam.. mostly curious.. and I'm sure it's 'better', but not sure all the ways that it would be 'different'. It makes sense what you say re the 'less lope' and smoother idle.. and more broad power curve, which is what I'd expect.
re last night's storms: we *(my wife and I, and our daughters and their families) spent several hours in the basement last night (amongst the car parts).. :) ... and we all survived the storms fine (no damage to us or our property), although a few miles away weren't so lucky - severe damage and some lives lost. It makes me sad what these storms do to some people's lives.. and they are very scary as they seem indiscriminate.. You are very lucky NOT to be in the path of a severe one. HOpefully tonight's storms won't be as severe as last nights...
I like hookers too (for power).. they seemed to be the preferred header for 302's even back when these cars were new (for the serious street/drag racers).. but those guys aren't generally concerned if they have to pound their firewalls a bit, or toss or bend the rev LO rods.. :)
Gary
I talked to Dave Crower extensively when he custom designed a 302 solid roller for me a few years ago.
I gave him everything for the car, weight, rear ratio, trans ratios, tire height, compression ratio, rod length, bore, stroke, he said that the most important set of figures was flow numbers on the heads from .100 to .700 every .100... (if you have stock unported heads the numbers are available) told him we wanted a nice lick and it would be drag strip/street fun driven 1000 miles a year. He had free reign
It also required larger springs, bronze cam gear, cam button.
I hate telling people the lift as it sounds outrageous for a SB (.636 Gross, with the ramps designed to open the valve quick then on close drop it just shy of the seat quickly then gently let it down on the seats so they don't get pounded into the heads.)
So what is/was your impression of that cam in driving the car, James? How was it different in performance, sound, idle, off-idle performance, etc... than the stock 302 cam?
Know what your saying ; .620 .620 ,310 duration in the drag motor ( sbc) does not sound radical at idle. average 680hp@7200 on the dyno. 550ft.lbs. @ 5500. Dart 2.08 heads ,long runner Dart intake. oops....wrong site !
Custom ground hydro roller. HP/torque crosses at 5500 ,lines run very close, almost parallel, no "hit" tolerates pedaling towards the beams very well without falling flat. Cam was spec'd for the car/engine package via the builder. You did it correct firstgenaddict.
I debated going with a roller in the Z but decided against having the heads cut for bigger springs. Currently it has a older Comp hydro which specs very close to the 30/30 (lift) without slamming the exhaust valves. Rhodes lifters and Harland sharp 1.5 roller rockers. Pleased with the way it ran in something else ,good vacuum, choppy idle. Nice pull to about 6800.
The duration was only 280 int 270 exh. The heads were gasket matched 186's with 2.05 Intakes plus we blended the radius on the seats.
It made 15" vacuum and was easy to drive, you could let the clutch out without revving the engine however it did have M20 with 4.10's.
Dave Crower said conservatively 330 Ft# @3500 and 490 Hp at 7000 said if tuned on a dyno I might get 15% better on the numbers.
I was very impressed, he is EXTREMELY knowledgeable and explained why he did what he did after giving me the specs. Besides the obvious factors of bore, stroke, & weight, flow rates and runner volume are as/if not more important factors to consider when designing a cam.
When I asked for a HP number He asked if I wanted something that would post a dyno number or something that would kill the dyno queen in real life?
The Pros know the numbers it's going to make. Have to know if the bottom end is strong enough. Not the worst thing hearing it fired and broken in on the dyno. Not to mention carb tuning.
Think you answered the question about Rollers: all around improvement. Like I said , you did it correct.
LOL, got off topic....headers?
Flat Black Jethot coated Hooker Supercomps
Back to my original question and forum topic...
I ended up building my own Super Scavengers and just wrapped up the install last week. Still a few more bugs to shake down with the project, which is why i haven't posted any progress info. Used some Hedman 65003 headers as my starting point since I wanted something cheap to chop up for my experiment. I'll post the fit issues with the the Hedmans if anyone is interested.
Attached are some pics if I can get them to work properly...
Bottom line - watch out for rookie welders with a MIG, some cold beer and too much imagination......
Charlie
Couple more shots...
Hedman before - no way it would clear the P/S box
Hedman after - why don't they build them this way? Perfect fit with zero clearance issues...
and you obviously told him you wanted to KILL the dyno queen... right? :)
How was the sound? any lope at all? or was the sound totally different than a stock 302.. no lifter clatter, etc???
My "dyno queen" sounds less radical than the solid lifter 302 did. And the current 302....all be true said.....apples and oranges in comparison between the two ;D
Beautiful work on the headers!
at idle....
( same 302, different cam)
Gotta say again, really nice work on the headers, they look great.
