Camaro Research Group Discussion => Maintenance => Topic started by: discobiscuit on June 30, 2013, 11:11:50 PM
I've replaced both front calipers, bled the lines and there are no leaks but when I apply the brakes the car pulls to the right.
Also...I'm unable to get the brakes to firm up. Should I bleed the rear brakes as well?
Thanks in advance for any help.
If you didn't replace the rubber lines, do so. They expand from within and is the major cause of pulling.
Defiantly replace the brake hoses if they are original and bleed the rears too. You should also check the rear shoe adjustment while you have the wheels off, you may have one rear braking that can contribute to a brake pull. George
