Camaro Research Group Discussion => Restoration => Topic started by: 69Z28freak on May 23, 2013, 12:19:24 AM
I blasted the centrelink and wondering how to get the best original looking finish so it will not rust.
(http://i65.photobucket.com/albums/h219/69z28freak/69%20Camaro%20Phase%202%20Part%202/IMG_8783_zps8163dbe8.jpg) (http://s65.photobucket.com/user/69z28freak/media/69%20Camaro%20Phase%202%20Part%202/IMG_8783_zps8163dbe8.jpg.html)
(http://i65.photobucket.com/albums/h219/69z28freak/69%20Camaro%20Phase%202%20Part%202/IMG_8784_zpsae6e7e35.jpg) (http://s65.photobucket.com/user/69z28freak/media/69%20Camaro%20Phase%202%20Part%202/IMG_8784_zpsae6e7e35.jpg.html)
I believe natural metal finish.
Here's mine removed and then restored Note factory paint dubs/smear:
(http://i1061.photobucket.com/albums/t478/jwlittooy/Camaro%20Suspension/CenerLinkMarking1.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/Camaro%20Suspension/CenerLinkMarking1.jpg.html)
(http://i1061.photobucket.com/albums/t478/jwlittooy/Camaro%20Suspension/SteeringLinkage4.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/Camaro%20Suspension/SteeringLinkage4.jpg.html)
And restored - degreased, light glass bead, Boeshield to protect surface from rust. Note that I didn't re-apply the big pink blob....
(http://i1061.photobucket.com/albums/t478/jwlittooy/Camaro%20Assembly/SubframewithSteeringLinkageAttached10_zps7f1a0161.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/Camaro%20Assembly/SubframewithSteeringLinkageAttached10_zps7f1a0161.jpg.html)
Hey Hans looks really good. What did you use to paint your subframe. How about the tie rods and other steering parts, are they new or did you restore them. All the parts have the same looking finish.
Thanks. Subframe was sand plasted, primed and then I applied a coat of 30% gloss lacquer...
The tie-rods are new (I still have the originals, may get rebuilt and install later); everything else is original, but was either lightly glass beaded or run through electrolysis to de-rust. Boeshield is all I applied. No rust at all to date. Every bolt is original as well - glass beaded and replated/phospated. Been fun, but very slow resto project.
Here's some before shots:
(http://i1061.photobucket.com/albums/t478/jwlittooy/Camaro%20Suspension/2188070444_zps5b5b1ddb.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/Camaro%20Suspension/2188070444_zps5b5b1ddb.jpg.html)
(http://i1061.photobucket.com/albums/t478/jwlittooy/Camaro%20Suspension/2188070440.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/Camaro%20Suspension/2188070440.jpg.html)
Would any of the center links be painted? I have one that was painted black with white inspections paint dabs.. Its the larger link might have been off of a Nova with A/C but can not remember for certain.
I didn't know you could restore tie rods. I opted for all new parts as I wanted to make sure that I have a safe set up. All of my steering parts were original. HBC has a made in USA suspension kit that I ordered.
My subframe was just blasted and it getting powder coated.
What is the finish on the steering box?
I really like the finishes on your car. They look great. I am hoping to have the same result if possible.
Did you re finish your drive shaft. I would like to compare notes with you so that I can get the best results.
Here are a few pics.
(http://i65.photobucket.com/albums/h219/69z28freak/69%20Camaro%20Phase%202%20Part%202/IMG_2399_zps1d618d11.jpg) (http://s65.photobucket.com/user/69z28freak/media/69%20Camaro%20Phase%202%20Part%202/IMG_2399_zps1d618d11.jpg.html)
(http://i65.photobucket.com/albums/h219/69z28freak/69%20Camaro%20Phase%202%20Part%202/IMG_8781_zpsf562a28a.jpg) (http://s65.photobucket.com/user/69z28freak/media/69%20Camaro%20Phase%202%20Part%202/IMG_8781_zpsf562a28a.jpg.html)
(http://i65.photobucket.com/albums/h219/69z28freak/69%20Camaro%20Phase%202%20Part%202/IMG_2315_zpsbeaac7c7.jpg) (http://s65.photobucket.com/user/69z28freak/media/69%20Camaro%20Phase%202%20Part%202/IMG_2315_zpsbeaac7c7.jpg.html)
What is the finish on the steering box & coil springs?
The drag link should be a blued steel. You can get it by using a good gun blue. I used gun blue on mine and treated it with sharkhide. I also finished my idler arm and drive shaft with sharkhide. The main mounting shaft for the idler arm should have the sameblue finish, the rest of the idler arm is natural steel.. I am sending a picture.
Can you post a pick of your drive shaft?
I blued mine also along with arm that goes to frame. On mine the arm was clean enough you could see the dark finish. There was a nos one on eBay showing the color also.very easy to do and cheap!
I debated with refinishing my original center link but decided to leave as is. The forged uneven finish would be hard to duplicate. Here are a couple pictures. George
George brings up a good point and one that should limit the preparation so not to harm the orig. finish. I had never read or saw a center link blued until I did mine two years ago (man how time files) and documented on my build thread ( http://www.camaros.net/forums/showthread.php?t=182584&page=14 ) here on page 14. Maybe it caught on or I was in the dark all along but never liked the look of cast blast colored links that never looked like that due to being a forging. I'd recommend not glass beading so the material is not altered and only removing grease and dirt via light detergents and soft wire brushing. Soaked mine in evapo-rust also! After cleaning I wire brushed it two complete times and cleaned with wax and grease remover three times prior to a simple bluing. After bluing neutralize with fantastic or 409 and I then protected mine with "rust prevention magic". I've completed a couple and they look great IMHO.
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/68%20Camaro%20Z28/100_5536.jpg) (http://s192.photobucket.com/user/1-2-b-67L89/media/68%20Camaro%20Z28/100_5536.jpg.html)
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/68%20Camaro%20Z28/100_5534.jpg) (http://s192.photobucket.com/user/1-2-b-67L89/media/68%20Camaro%20Z28/100_5534.jpg.html)
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/68%20Camaro%20Z28/100_5531.jpg) (http://s192.photobucket.com/user/1-2-b-67L89/media/68%20Camaro%20Z28/100_5531.jpg.html)
Our Idler Arm black portion of the arm that mounts to the frame had a different look than the center link. It was a black natural finish but did not have the black/blue forging look the center link had but luckily on ours that portion of the arm is all original and has not been altered. Some before and after pics.
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/68%20Camaro%20Z28/100_5499.jpg) (http://s192.photobucket.com/user/1-2-b-67L89/media/68%20Camaro%20Z28/100_5499.jpg.html)
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/68%20Camaro%20Z28/100_5497.jpg) (http://s192.photobucket.com/user/1-2-b-67L89/media/68%20Camaro%20Z28/100_5497.jpg.html)
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/68%20Camaro%20Z28/100_5526.jpg) (http://s192.photobucket.com/user/1-2-b-67L89/media/68%20Camaro%20Z28/100_5526.jpg.html)
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/68%20Camaro%20Z28/100_5525.jpg) (http://s192.photobucket.com/user/1-2-b-67L89/media/68%20Camaro%20Z28/100_5525.jpg.html)
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/68%20Camaro%20Z28/100_5524.jpg) (http://s192.photobucket.com/user/1-2-b-67L89/media/68%20Camaro%20Z28/100_5524.jpg.html)
Since the drive shaft was basically a steel tube with a part welded at each end we had ours placed on a lathe so we could remove some of the tubes roughness and pits from rust normally toward the rear. A little tip in detail involves taping off and bluing the weld area since our weld area got polished somewhat in the resto process.
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/68%20Camaro%20Z28/100_6264.jpg) (http://s192.photobucket.com/user/1-2-b-67L89/media/68%20Camaro%20Z28/100_6264.jpg.html)
People with no industry experience see a sandblasted clean part and assume that's what the metal originally looked like. Same with coil springs. Most are sprayed with Cast Blast or silver paint and look nothing like a freshly manufactured part. Go walk through a steel supplier, spring shop or watch a blacksmith to see how metal's appearance is affected by heat. "Cast" Blast is what the name impies and is not what forged metal looks like.
I have great pictures of my 69 Z suspension as I was pulling it out of evap o rust. All the original factory dab marks starting appearing as the surface rust was washing away. It was very cool. The problem is the the picture sizes are large to post on here. I will be happy to email to anyone interested.
For reference, here's some more pics consistent with what others have posted regarding center link and idler arm finishes - after I cleaned them up but before installed on the car. Mostly just degreased the parts. Idler arm part that mounts to frame has blackish finish and center link was grayish and maybe with hints of blue:
No paint on the parts....only applied Boeshield.
(http://i1061.photobucket.com/albums/t478/jwlittooy/Camaro%20Assembly/SteeringLinkage-Restored12_zps7ccff907.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/Camaro%20Assembly/SteeringLinkage-Restored12_zps7ccff907.jpg.html)
(http://i1061.photobucket.com/albums/t478/jwlittooy/Camaro%20Assembly/SteeringLinkage-Restored13_zpsadfe9727.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/Camaro%20Assembly/SteeringLinkage-Restored13_zpsadfe9727.jpg.html)
(http://i1061.photobucket.com/albums/t478/jwlittooy/Camaro%20Assembly/SteeringLinkage-Restored3_zps879b0566.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/Camaro%20Assembly/SteeringLinkage-Restored3_zps879b0566.jpg.html)
(http://i1061.photobucket.com/albums/t478/jwlittooy/Camaro%20Assembly/SteeringLinkage-Restored5_zps6f24039a.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/Camaro%20Assembly/SteeringLinkage-Restored5_zps6f24039a.jpg.html)
(http://i1061.photobucket.com/albums/t478/jwlittooy/Camaro%20Assembly/SteeringLinkage-Restored2_zpsffb56aed.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/Camaro%20Assembly/SteeringLinkage-Restored2_zpsffb56aed.jpg.html)
Looks great Hans. Nice to see the Cortez Silver shell in the background.
Thanks Mike! Can't wait to get it done. Restoring all the subcomponents seems to take forever. One of these days, I'll start a build thread on Team Camaro. I've been following yours - some good info I've picked up from your thread there.
